| Chip Amps Amplifiers based on integrated circuits |
I recently finished a GC using Brian's kit. I'm impressed initially with the sound but last night I replaced an AVA mosfet 100w/chan (old Dynaco ST150) with the gainclone and noticed not so good bass performance. The application is a bi-amplified speaker system using a S&B TX102 TVC driving an active xover. Signal below 200 hz is sent to the GC (or mosfet amp) for bass duties. Speakers are big Altec 515s. What I'm hearing...... the mosfet amp gives tighter more tuneful bass performance. The GC is a little uncontrolled and tubby sounding. Bass notes seem to all run together.
Any idea how to analyze this problem to see if it is an impedance issue? Jim D. |
#2 |
As I recall, GC builders use more supply capacitance when the amp is confined to bass duties. Try 10,000 mfd.
#3 |
lots of capacitans and a snubber should do the job. 2*1500uf on chip is nothing near enough for bass, and not enough for anything else either, or at least so i think, having compared 2*1000uf per board, 2*1000uf per board+2670uf per rail in the PS, 2*1000 per board+6200 in the PS, and finally, and what i ended up using, 2*1000uf per board+ 6200uf per rail en the PS with a snubber. read carlosfm's post about the big capacitans psu for chipamps. it's on the first page.
regards marius |
| impedance mismatch | ddoyle | Multi-Way | 6 | 17th January 2008 04:06 PM |
| INA134 and input impedance mismatch | redrabbit | Solid State | 20 | 30th September 2007 09:38 AM |
| Impedance Mismatch | sushizen | Full Range | 1 | 16th November 2006 01:18 PM |
| impedance mismatch headaches. | xstephanx | Multi-Way | 11 | 10th April 2006 07:36 PM |
| Page generated in 0.07840 seconds (72.18% PHP - 27.82% MySQL) with 10 queries |
