Can i paralel the 2 opamps in 5532?
Old 15th December 2004, 07:12 AM   #1
jondoe is offline jondoe  Romania
jondoe's Avatar
Default Can i paralel the 2 opamps in 5532?
Can i use a 5532 but with the opamps in paralel?
I would want to use this circuit
http://www.tnt-audio.com/clinica/dynamicopamp_e.html
but with unity gain and with some easy to find (like the 553*) and inexpensive opamp.
I could use the 5534 but i don't have the tools to compensate it into unity gain (osciloscope etc.).
I tried sometime in the past with 5534 but didn't compensate (or not quite right) and it wouldn't work, it had high dc output & i guess it was oscillating (no surprise here now that i think of it).
Or can i just use a paralel 5532 for a line driver ?
Will there be any problems, load sharing resistors, bias differences ?
Old 15th December 2004, 06:17 PM   #2
Mr. Triatic is offline Mr. Triatic  Sweden
Mr. Triatic's Avatar
there was no page where the link pointed..
well, you can parallell opamps, but there's one important rule and that is to use a resistor in series with the output and after that resistor you can tie the outputs together, those particular resistors makes sure that those opamps feels good and delivers!!
>opamp output >------[4,7ohm]------->connect with other opamp/resistor
it doesn't matter if they're on the same chip or not..
www.joddla.net/audio/
Old 15th December 2004, 07:08 PM   #3
by the way... there was a guy who buildt a poweramplifier using an unholy amount of small opamps.. just parallelling them into one output.. if i remeber correctly there was 44 pcs per channel!!
-i can't remember his homepage, but i'm sure it's out there...
Old 15th December 2004, 07:26 PM   #4
Nicke is offline Nicke  Sweden
Nicke's Avatar
Default Poweramp with mant opamps
Could it be this one?
44 pieces of opamp power amp
Old 16th December 2004, 07:06 AM   #5
jondoe's Avatar
Default OK, got it
The link is ok from here.
That's the amp.
I allmost fell from my chair when i first saw it.
I'm not that crazy. I just don't have the finances to buy one of those really hi-end opamps hence this idea.
If you really can't see the page, here is a zip of it.
Old 16th December 2004, 02:37 PM   #6
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
jondoe!! Pls check the attachment u posted....
SivanandBalan
Old 17th December 2004, 05:53 AM   #7
jondoe's Avatar
Default What's wrong with it ?
Am i missing something here ?
I don't see it containing anything obscene...
neither it mentioning something about what i would want, or is it...
Maybe i'm just sloppy...
Or the file is broken,
WHAT is it ???
Pls, enlighten me.
Can i paralel the 2 opamps in 5532?Hide this!Advertise here!
ne 5532 replacement intense-tavda Digital Source 3 30th August 2013 01:52 AM
paralel MOS-FETīs HELP viki Solid State 4 17th September 2004 02:59 PM
TDA 7293s paralel ,voltage... B.I.G Chip Amps 0 18th March 2004 09:37 PM
Paralel resistor jan Multi-Way 9 5th September 2003 06:11 AM
Paralel CS8420 & CS8414 A'af Digital Source 10 16th January 2003 03:19 PM
Copyright ©1999-2017 diyAudio
