| Chip Amps Amplifiers based on integrated circuits |
I built a parallel bridged amp with 8 lm3886 I measured the voltage at the output Im getting 3volt dc and 32volt ac when the amp in wide open. Is the normal
#2 |
No.
Nothing is as simple as it seems |
#3 |
time to go over the amp with your multimeter and check every solder joint and wire in the amp.
do you have a dc servo in your amp considering you have so many chips? marius |
#4 |
I got you Marius:
Your sig relates to the winter season when most of you put on your skis and take off into the wilderness! Of course there are no toilets, and you will find places where the snow has a golden color!! Hence, the proverb says - directly translated: Cook never coffee on yellow snow!, or better: Never make your coffee based on water from yellow snow! As a proverb, absolutely NOT dirty! The coffee on the other hand ......! Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#5 | |
You must tell us a bit more. Post a schematic diagram. What do you mean with "the amp is wide open"? Have you measured with the input shorted? If not, do that first. Jan Didden
#6 | |
DAMN! you spoiled the fun for me now!! I'l have to come up with something new now i guess.. but tell me.. who's your inside source? ontopic: yes, post schematics. that always helps. |
#7 | |
Jan Didden
#8 |
what i mean by "wide open" is the volume control is turn completely to the right. I used the classic inverted design and there is no servo just trimmer at +input
#9 | |
Banned
#10 | |
Electrons are yellow and more is better!
"Koka aldrig kaffe på gul snö" in swedish. Sometimes you are slow.... Jan, what about my sig at the bottom?
/Per-Anders (my first name) or P-A as my friends call me |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 06:10 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 11:18 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 07:15 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 06:17 AM |
| I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output | iklari14 | Digital Source | 30 | 18th July 2003 01:57 PM |
| Page generated in 0.11509 seconds (83.14% PHP - 16.86% MySQL) with 10 queries |
