Hum
Hum
Old 14th December 2004, 01:56 PM   #11
rs1026 is offline rs1026  India
Default No Diff
No difference its exactly same.Only thing is I have put everyhting into a metal box now before it was just lying on a piece of wooden board.
Old 14th December 2004, 02:01 PM   #12
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Hum
I'm not totally convinced that this is all the truth. Can't you take picture?
Is it "soft" hum 50 Hz even with input shorted? Is it "hard" 100 Hz hum with lot's of harmonics.
50 Hz, problem with ground loops and the input.
100 Hz some trouble with your power supply and grounding technique.
Is it a stereo amp (yes), one transformer(yes) , same hum in both channels?
Is the transformer more near your Lm3886 now than before? (picking up magnetic field)
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 52 pcb's in order. 31 paid.
Old 14th December 2004, 02:35 PM   #13
Default ..
I dont have a Digicam thats the problem.
Its a soft hum not very loud.But it is noticeable.
yes,It is a stereo amp.Single transformer.Yes the hum is same in both the channels.
Yes,Now its is very near one of the lm3886 chips.before everything was spread out.So could it be magnetic field?
Can I connect the PCB grounds,mains earth to a single point on a chasis??
Old 14th December 2004, 03:36 PM   #14
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
This is explained on the FAQ page! That's why I asked if you had read it.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 15th December 2004, 08:23 AM   #15
peranders's Avatar
Hum
Default Re: ..
Try to move the transformer, less hum?
A toroid can be placed very near the electronics but a EI core has much more magnetic leakage.
Old 17th December 2004, 04:31 AM   #16
gmphadte is offline gmphadte  India
If u cannot move the transformer away from the electronics, put one iron sheet covering over the transformer(s). Need not be air tight as ventilation is necessary. This helps a lot.
Gajanan Phadte
HumHide this!Advertise here!
Resources saved on this page: MySQL 17.65%
