| Chip Amps Amplifiers based on integrated circuits |
Hi Peter, Brian,
looking at the nigc_kit-users_guide.pdf document, I see that your rectifier boards are assembled without any heatsinks on the diodes (MUR860s). From another one of my posts, Per-Anders states that anything higher than 3A through the MURs would require a heatsink!? My Regulated PSU will use a LM338 regulator which is a 5A regulator. So the max through the diodes I would expect would be 5A. Do I need a heatsink? And why arent you guys using them? |
#2 |
Peranders probobly ment that anything above 3A, continious needs heatsinking your regulator will not constitue a continious load so you will be okay.
/ micke |
#3 |
Electrons are yellow and more is better!
Exactly
Your MUR860 can take 8-10 A with good cooling and transientwise much more. If you look around, how many Gainclones with heatsinks on thier rectifier bridges have you seen? Correctly, none.
/Per-Anders (my first name) or P-A as my friends call me |
#4 | |
Well Per-Anders dude, you are confusing me. This is what you said initially:
So, which is it? I dont have the luxury to see whether they need heatsinks or not as that will mean another PCB design! |
#5 |
In normal use, at reasonable levels, the current flowing is is lower than 3A. If you were using the amp for long periods at high levels, then it makes sense to add heatsinks.
Why don't you just design a pcb with room for heatsinks, then you can add them later if required.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
Sometimes the diodes get pretty warm, but they don't need heatsinks (when you run 2 channels only).
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
| BYW29 instead of MUR860 | endia | Chip Amps | 6 | 21st January 2009 02:56 AM |
| MUR860 still good or not? | HellviS | Parts | 2 | 9th April 2006 09:49 PM |
| Why the MUR860 diode? | meat | Chip Amps | 24 | 15th March 2006 07:35 PM |
| Is it normal that my MUR860's ... | jpg | Chip Amps | 4 | 18th February 2006 07:31 PM |
| MUR860's in BZLS PSU | moe29 | Pass Labs | 2 | 6th February 2005 04:22 PM |
| Page generated in 0.08423 seconds (74.79% PHP - 25.21% MySQL) with 10 queries |
