| Chip Amps Amplifiers based on integrated circuits |
Hi!
Plenty years ago I have read an article about a moving opamp to Class-A. The idea is very simple. An opamp's output stage is in Class-AB. We connect source current between the opamp's output and a negative power suplier voltage. If signal output current is less than this CS current, only up (npn) transitor works: it is always open and work in Class-A. I'd like to know current state of this idea. Especially, I'm interested in audio listening experience of such trick. If your amplifier is under designing now, you can try the idea during few minutes! :-) If an audio signal output is about 1mA and opamps works well with 10mA output current, the simplest way is to try to connect the opamp output with negative supplier -15V voltage through 3K resitor. Andrew |
#2 |
Hang around www.headwize.com and you will find lots of information on this technique. Or you could search here as well, it's been covered a lot.
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 02:15 PM |
| Let's get the wiki moving .... | paulspencer | Subwoofers | 0 | 18th October 2005 05:11 PM |
| opamp class a again | pxr5 | Solid State | 0 | 9th November 2004 05:24 PM |
| opamp 'class A' biasing?? | rsrphotos | Solid State | 2 | 28th September 2004 10:24 PM |
| Opamp in class A? | Ryssen | Solid State | 4 | 29th February 2004 06:40 PM |
| Page generated in 0.06762 seconds (69.57% PHP - 30.43% MySQL) with 10 queries |
