is direct soldering better than ic base?
Old 9th December 2004, 09:51 AM   #1
Roushon is offline Roushon  India
Default is direct soldering better than ic base?
for op-amps in audio circuits is direct soldering better than using ic base?
S. Roushon
Old 9th December 2004, 10:38 AM   #2
ashok is offline ashok
ashok's Avatar
IMHO ....yes.
However if you want to test different chips you will obviously need one. When you say audio chips I guess you mean circuitry for audio use. That might use very wideband chips which might need to be tamed if mounted on a socket. You will find that many chips for audio use are extremely wideband - seemingly unnecessary but audibly proved otherwise.
Used carefully , you can get by with (machined) sockets.
There are some pictures on some other thread. Do a search.
Cheers.
AM
Old 9th December 2004, 12:19 PM   #3
Markje is offline Markje  Netherlands
If you use a good socket it is not a problem (in my opinion).
edit: by that I mean, no difference.
Greetz Mark
Old 9th December 2004, 12:22 PM   #4
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
The only reason for using a IC socket is if you want to replace the IC in a easy way, for test purposes etc but normally avoid it!
If you do want to use a socket for some reason, use a socket of good quality with round holes with "tulip" contacts.
Good socket below.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 9th December 2004, 12:28 PM   #5
peranders's Avatar
Not so good but cheaper.
Old 9th December 2004, 12:59 PM   #6
ajju is offline ajju
If your soldering skill are not that sharp and u fear damaging the component or if its some real sensitive one...going the socket way is a good option initially...!!
Old 9th December 2004, 02:19 PM   #7
jackinnj is online now jackinnj  United States
jackinnj's Avatar
you can get very high quality machined headers -- these come in rows of 25 -- just snip what you need
when I am using DIP ADC's or DAC's I use a socket in the protos -- but there is quite a bit of capacitance and inductance in a "leaded" device vs an SMT device.
Old 9th December 2004, 02:44 PM   #8
yes...the stray elements are something to worry about at high frequencies...Especially if ur doing radio work or clocking above 30-50Mhz digital, sockets are a strict no no..!!
Old 9th December 2004, 02:58 PM   #9
jackinnj's Avatar
you don't socket a high speed current feedback amplifier...
Old 9th December 2004, 03:19 PM   #10
Any high speed device(or high bandwidth device) operated at full or near full bandwidths or high gains might suffer from parasitics if not adequetly taken care off...!! Lead inductances, inter-lead coupling capacitances etc shows pronounced indulgance especially at high frequencies.
is direct soldering better than ic base?Hide this!Advertise here!
Base Stoppers lumanauw Solid State 72 22nd September 2010 02:30 PM
Direct (or almost direct) replacement for Morel MW144? mr_push_pull Multi-Way 1 19th April 2009 04:43 PM
base for amp karma Tubes / Valves 7 18th June 2004 03:03 AM
Very expensive binding posts vs Direct soldering roibm Chip Amps 25 21st April 2004 11:41 AM
Bed base as a big sub? DPW666 Multi-Way 9 10th March 2003 07:48 PM
Copyright ©1999-2017 diyAudio
