Zobel network.....Better bass? Yes or No
Old 17th June 2014, 11:58 AM   #21
DF96 is offline DF96  England
This thread seems to be confusing two quite different uses of a 'Zobel network'.
One is across a driver so that the crossover network sees a closer approximation to a resistance.
The other is across the amp output (usually in conjunction with an inductor) to maintain ultrasonic stability in the feedback loop.
Which are we talking about?
Old 17th June 2014, 01:28 PM   #22
Posts 1 to 8 inclusive, are only considering Amplifier Output Zobel.
Post9 is the first to introduce the Speaker Zobel.
That is a different subject.
Post19 is discussing the speaker Zobel.
This is an amplifier Thread, not for speaker tuning.
regards Andrew T.
Old 17th June 2014, 02:51 PM   #23
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
And ten years to late.
Regards Mark.
Old 23rd October 2017, 03:20 PM   #24
kpsthakur is offline kpsthakur  India
Lightbulb Trying to increase Bass and reduce offset
Originally Posted by basi View Post
Hi!!!
If you need more bass and better control of sound then add 10 000uf to your
power supply.
And increse input and feedback cap.
Example 10uf input,100 uf feedback.
I tried your suggestion rolloff expected at 2.3 Hz for 680Ohm/100uF Ri/Ci setup...gain designed in my Gainclone is close to 32.
There is a huge improvement...question back to you is in this case how far can I increase Ci value...can't this go higher...e.g. 1000uF... with the same setup I may reach 0.2 Hz, technically not lose any audible bandwidth....I am doing something very wrong here
Next query will be around DC offset...what happens if I use a 4700uF cap at output...it certainly should take care of my DC offset, but what will it destroy in audio bandwidth
Old 23rd October 2017, 03:27 PM   #25
starkeyg is offline starkeyg
Hello,
There is a point of diminishing returns. Especially as over 98% of music does not go down below 30 hertz.
As far as the cap blocking DC on the output - there is a reason that is not done by pretty much anyone since the 1970's. Caps large enough to be used here are pretty much electrolytic's, and far less than ideal caps. Far better to use a DC servo to eliminate any DC offset or use a design that minimizes the offset.
Old 23rd October 2017, 03:42 PM   #26
Originally Posted by starkeyg View Post
Hello,
Thanks Starkey
I understand, however I am looking for quickfix as I am learning while I am burning...don't want to mess with my speakers...I took this input from test circuit from LM3875 datasheet...
DC servo...something I have not yet jumped in...but heard this term few times in other forums...will try and understand more about it.
Cheers
Old 27th October 2017, 06:34 PM   #27
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I don't think a zobel makes any difference to the sound at all.
The amp output impedance is so low it drowns out any effect the zobel might have.
The zobel just cancels out some of the speaker inductance and gives the amp a more constant load.
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 27th October 2017, 07:35 PM   #28
the Amplifier Output Zobel is typically 10ohms+100nF
That has an F-3dB of ~160kHz
At 160khz the Zobel has a reactive impedance of 10hms and a real impedance of 10ohms giving a total impedance of ~14ohms.
The amplifiers sees the Output Zobel as a 14ohms load @ 160kHz.
At 20kHz the combined impedance has risen to ~80ohms.
This would be in parallel to the speaker load.
It should be completely inaudible.
regards Andrew T.
Old 28th October 2017, 02:12 PM   #29
indianajo is offline indianajo  United States
indianajo's Avatar
I own an amp that came without a zobel on speaker terminals, a dynaco ST120. I added it myself, diy. The bass wasn't audibly different before or after the "TIP mod", always quite satisfactory, but the RF interferance before addition certainly was. I had to do other mods also to get rid of an AM radio station.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Zobel network.....Better bass? Yes or NoHide this!Advertise here!
zobel network and cat5 reddish75 Chip Amps 5 17th January 2007 10:31 PM
Zobel Network JiggaD369 Multi-Way 9 5th May 2005 01:27 AM
Zobel Network nuttinbutSQ Multi-Way 6 16th March 2004 09:19 AM
Copyright ©1999-2017 diyAudio
