TATCA - Tiny And Transparent Chip Amp
Old 10th December 2004, 11:05 PM   #31
Upupa Epops is offline Upupa Epops  Czech Republic
Gentlemen, are you meaning your applauding seriously ?
Old 11th December 2004, 12:55 AM   #32
falcott is offline falcott
falcott's Avatar
Yes.
"Everything should be made as simple as possible, but not simpler." - Einstein
Old 11th December 2004, 09:00 PM   #33
Sandy H. is offline Sandy H.  United States
Sandy H.'s Avatar
Upupa,
I think Vikash is a very accomplished web designer for sure. I personally thought his choice to build a nice small chassis using clear materials to show off the boards inside was much nicer than a plain black rack mount chassis.
On the other hand, I have seen some of the boards I believe you have designed and posted and they look very impressive as well. I'm not sure of the details, though, as the threads seem to often get muddled in people arguing and I stop reading at that time. If you had a website that shows some of your projects without the forum arguing, I'd like to learn more about that too.
Vikash gave both and I enjoyed it and still think congratulations are in order.
Sandy.
Old 12th December 2004, 03:26 AM   #34
neutron7 is offline neutron7  Canada
neutron7's Avatar
I think that looks great in a "case mod" sort of way. are you making up for the fact you have a laptop
Old 12th December 2004, 11:04 AM   #35
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Hey guys, can we leave the negativity out please. There really is no reason for it in this thread. It is about a nice looking chassis design, not anything else...
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 13th December 2004, 09:47 PM   #36
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Originally posted by falcott
Peter, how much current do you think computer cable/plugs can carry? Should 2 pins/wires be used for each voltage rail when used as umbilical for a 3875 or 3886 chip amp? I'm guessing that a single wire is right on the edge...
Cheers.
Not sure how thick computer cable is, but I made the umbilical using stranded cable 0.5mm2 and it seems to be fine. I'm quite enjoying it but for the attenuator. Not nearly enough steps for my taste.
It's ironic that I hate that PC case mod look but still managed to create something you might describe as similar too I actually wanted something that would sit on top of my pillar of external computer peripherals (modem, router, sc break out box...) - hence the size and dimensions of TATCA. Not sure if RFI will allow this though
I tried some holes in the top, but it didnt turn out too well. Probably try again with another design before reverting to plain and simple again.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 14th December 2004, 02:17 AM   #37
edjosh23 is offline edjosh23  United States
edjosh23's Avatar
That about a design in the top?
Maybe a little to childish but you could try doing something neat with the word "Gainclone" or "GC" besides the Gucci sign
or maybe not
Old 14th December 2004, 04:52 AM   #38
ROVSING is offline ROVSING  Denmark
ROVSING's Avatar
Hello Vikash
Earlyer in this thread you mentioned that you would like to make the panels less blend, if you know someone working with stainless steel they probably have the tools for glassblasting (i'm not sure if its called that in english) it's the same as sandblasting using very fine glasspowder instead of sand, this will give the surfaces a nice diffuse look still being able to see the shadows of the components through it.
The material is to "soft" to get a good result using grindingpaper.
You have to be very carefull blasting it, the "glasspowder" is "eating" the material rather fast.
Frandsen
TATCA - Tiny And Transparent Chip AmpHide this!Advertise here!
Tiny, tiny DC-DC converter jackinnj Power Supplies 1 28th June 2006 07:03 PM
TATCA - Finally Completed + Images Vikash Chip Amps 12 31st March 2005 01:56 PM
Transparent Baffle bzdang Multi-Way 19 19th July 2004 10:48 AM
any good tiny tiny tweeters? THOR Multi-Way 18 28th June 2004 06:42 AM
