| Chip Amps Amplifiers based on integrated circuits |
#21 |
Actually if you take a piece of alu and a piece of copper with identical measures, the dissipation will be exactly the same, but copper will lead the heat faster away from the heat source to dissipation.
Painting it black will make the dissipation better in both cases. So Vikash you are right about copper conducting better.
Frandsen |
#22 |
As Daniel pointed out: Surface (exposed to (free) flowing air) is the key factor in getting rid of the heat. In view of the free exposure copper will do better in the Peter Daniel design, where as far as I can see only the backside is freely exposed.
E&E |
#23 |
I'm using perforated aluminum top panel, and this dissipates most of heat in Patek design.
With the integrated chassis, the copper piece is connected to rear panel (which surface by itself is big enough), but it also connects to the mid plate, which in turn is connected to the top panel. In any case, GC generates very little heat, and dissipating it shouldn't be a problem in most designs.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#24 |
As to the computer cables, I'm not sure how much current they can take, but if you put them in parallel (per rail), chances are they will work.
#25 |
diyAudio Moderator Emeritus
Vikash,
Looks nice! What does your power supply chassis look like? -- Brian |
#26 |
Temperature transfer of copper ( against aluminium ) is similar as electricel conductivity - difference is a few percent
#27 | |
![]() I'll start on it soon hopefully, and want it to be a simple dark block for the amp to sit on.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#28 | |
#29 |
Nice work
I Like the ideia.... small, simple and we can say original When you finish, tell us about the sound quality
#30 |
Vikash,
Your amp is very well done. From your attention to your own site and others you have designed, I can tell you are a designer with a keen eye. I hope to see more of what you are doing, as it is very well thought out and is much more of a success than most comercial designs I see. Thank you, Sandy. |
| Tiny, tiny DC-DC converter | jackinnj | Power Supplies | 1 | 28th June 2006 07:03 PM |
| TATCA - Finally Completed + Images | Vikash | Chip Amps | 12 | 31st March 2005 01:56 PM |
| Transparent Baffle | bzdang | Multi-Way | 19 | 19th July 2004 10:48 AM |
| any good tiny tiny tweeters? | THOR | Multi-Way | 18 | 28th June 2004 06:42 AM |
