TATCA - Tiny And Transparent Chip Amp - Page 2 - diyAudio
Old 8th December 2004, 01:44 AM   #11
edjosh23's Avatar
I really like the TATCA and love the oversized heatsinks.
I see you and Peter Daniels use serial ports from the rectifier. Are they hard to wire? What awg are the serial wires? How much power can they handle?
Where did you get the knob?
Do you prefer Brian's old boards over the new ones with the Zobel or were those boards laying around the house?
Thanks,
Josh
Old 8th December 2004, 02:32 AM   #12
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
I was going to go with a 9 pin D type connector but then I wouldn't have enough pins to power LED's as well. The denser 15 pin version is easy enough to work with. I used 16/0.2 (0.5mm2) equipment wire for the connections. The longest runs within the amp are less than 4 inches.
I haven't made the umbilical cable yet, and interested myself what Peter used for this purpose.
The knob is from RS Components (not Radio Shack). On your side of the pond you have much more variety and accessibility to control knobs.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 8th December 2004, 04:05 AM   #13
edjosh23's Avatar
What type of power supply are you thinking about using?
(I was just reading the thread about GC speakers) what speakers are you going to power?
Thanks,
Josh
Old 8th December 2004, 04:41 AM   #14
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Personally, I prefer the old boards, because Zobel network messes up the ground plane in case you are not using it (and I never do)
As to the umbilical cable, you can basically use anything: CAT5 comes to mind, I'm still using Cardas 20ga, and some ready made, computers cables are available as well (and they are already terminated).
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 8th December 2004, 05:01 AM   #15
Sweet...
Old 8th December 2004, 05:36 AM   #16
falcott's Avatar
Originally posted by Peter Daniel
... computers cables are available as well ...
Peter, how much current do you think computer cable/plugs can carry? Should 2 pins/wires be used for each voltage rail when used as umbilical for a 3875 or 3886 chip amp? I'm guessing that a single wire is right on the edge...
Cheers.
"Everything should be made as simple as possible, but not simpler." - Einstein
Old 8th December 2004, 09:30 AM   #17
ROVSING is offline ROVSING  Denmark
ROVSING's Avatar
Very nice work vikash !
I am going to build my gainclone like that, using cupper flat bars as heatsinks instead of aluheatsinks to make it even smaller.
Keep up the good work - i'm inspired.
Frandsen
Old 8th December 2004, 09:43 AM   #18
Electrons are yellow and more is better!
peranders's Avatar
Don't forget that the surface area is the most important thing. A flat copper bar is proabaly much worse heatsink than a regular shaped one in aluminium.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 8th December 2004, 10:13 AM   #19
ROVSING's Avatar
In this case, Per Anders, i don't think that it matters i am going to use flatbars measuring 100*50*10 mm, one for each chip/side - copper leads the heat away twice as good as aluminium, if you take a look at Peter Daniels gainclone in the BrianGT gallery i suppose that he also used copper ca. 25*25*100 mm fore both chips, the coolingarea are much smaller there, but i'm sure that it works fine. (sorry if i'm wrong Peter D i was just guessing....)
Frandsen
Old 8th December 2004, 10:51 AM   #20
Vikash's Avatar
I believe copper conducts better, but alu dissipates heat better. Either way any heatsink that thickness I would presume to be ok.
Tiny, tiny DC-DC converter jackinnj Power Supplies 1 28th June 2006 07:03 PM
TATCA - Finally Completed + Images Vikash Chip Amps 12 31st March 2005 01:56 PM
Transparent Baffle bzdang Multi-Way 19 19th July 2004 10:48 AM
any good tiny tiny tweeters? THOR Multi-Way 18 28th June 2004 06:42 AM
Copyright ©1999-2017 diyAudio
