| Chip Amps Amplifiers based on integrated circuits |
I'm interested in using gainclones for a set of active monitor speakers, how powerful can you make gainclones?
#2 |
Electrons are yellow and more is better!
200-400 W if you bridge connect and if you use one or two in parallel you can get 50-100 W.
You could also consider an 180 or 400 W module from www.hypex.nl
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
But having more than a pair of chips increases the complexity to the equivalent of building a discrete amp...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
Ok so how powerful can I make an easy simple to build gainclone?
I would like about 30Watts for a tweet and about double that for a midbass. |
#5 |
By careful selection of your drivers you can accomplish the same end. Choose a tweeter that is 8 ohms, a midrange that is 4 ohms, and a woofer that is 8 ohms. Now you make 4 amps; one for the tweeter, one for the midrange, and two bridged for the woofer. That way you have the most simple way of making amps that increase two-fold in power rating.
For example: If your tweeter amp is 30 watts, then the midrange is (approx.) 60 watts, and the woofer is 120 watts. The beauty of this simple system is that you can use the same power supply for all the amps (in the above example at least 400 VA transformer, ie roughly twice the listed output rating).
Hmm .. no .. I really haven't got anythig cool to say .. |
#6 | |
Not that I'm anywhere near that, but the thought intrigues. Dave
I have a small website for my projects. |
#7 | |
| Powerful bass | syl | Solid State | 13 | 2nd July 2007 10:29 PM |
| Help!very Powerful Amp Needed! | hernanstafe | Solid State | 8 | 15th March 2007 01:30 AM |
| New way to make a balanced gainclone? | MtBiker | Chip Amps | 1 | 18th August 2005 04:11 AM |
| simple but powerful | sr2002 | Chip Amps | 19 | 1st August 2005 06:20 PM |
| Any advantage to make dual mono (PSU) for the gainclone (I'm ordering Brian GT's kit) | dw1narso | Chip Amps | 26 | 5th April 2004 01:14 PM |
| Page generated in 0.07974 seconds (78.44% PHP - 21.56% MySQL) with 10 queries |
