| Chip Amps Amplifiers based on integrated circuits |
I am designing a PCB based on carlosfm's thread in regards to Regulated PSUs.
The attached screenshot is of half the board. The other half will be a mirror image. The intention here is to get feedback on my current design and how I can improve it before I go and do the other half. This design is for DIY only, and I will not be making it commercially avalable, so now that we got that out of the way, please fellas, post your comments. Thanks! |
#2 |
what about the U1?I recommend that you should leave some rooms for set up U1's heatsink.
digi |
#3 |
The actual heatsink will be U-shaped with the fins extending to the front of the regulator.
The only reason I put them so close together is because carlosfm suggested that C3 should be as close to the regulator as physically possible. |
#4 |
here is the finished product:
#5 |
And this is what it might look like:
#6 |
In my opinion the left side of the board can be made simpler (and this will make the board small) if the following idea is used.
S. Roushon |
#7 |
I see your point, however the way you see it there, it is because of the actual PCB connector that I will be using for the incoming AC from the toroid.
Here is the part: |
#8 |
Hi D_GR8_1
I like your connector, where did u get it and how much are they? regards Arthur |
#9 |
They are available in Jaycar and are about AUS$3-4.
I am actually getting all my supplies from a Jaycar supplier, a company called Electus, where everything is half-price!
#10 |
Banned
no offence . but digi's are smaller and would work better small mans smaler chassis. and on the other note you can use peter daniel's SUPERB chassis. : O )
| Regulated or non-regulated SMPS | longitude | Class D | 5 | 8th May 2007 03:02 PM |
| Need a little help with my first regulated PSU | jarros | Power Supplies | 16 | 2nd May 2005 11:28 PM |
| Regulated PS Kit | cantskienuf | Chip Amps | 7 | 24th September 2004 03:20 AM |
| Regulated PSU Help.. | jleaman | Analogue Source | 9 | 26th July 2004 12:36 PM |
| Regulated or no regulated PSU? | Higo | Chip Amps | 2 | 16th July 2003 04:38 PM |
| Page generated in 0.10255 seconds (73.92% PHP - 26.08% MySQL) with 11 queries |
