| Chip Amps Amplifiers based on integrated circuits |
Hi, sorry for posting yet another gainclonetread but after reading a bunch of threads at different forums I got many questions with different answers. So I just need confimation on a few things
![]() It's Brians Basic stereokit lm3875 btw. 1: Do you get 56W out of this kit? I will be usings this amp to drive a pair of shelfspeakers with efficiency in the lower 80db's and they seem to like some power to sound right. 2: What transformer is optimal for 8ohm speakers? 2x22V and 100-150VA/channel? I've found these: 2x18@220VA 2x20@220VA 2x22@220VA 2x18@300VA 2x20@300VA 3: Is it enough to mount the 2 chips at a bottomplate of aluminium roughly 20x15cm with 1-2cm airgap underneath? 4: Regarding a Pot to the volumecontrol, (no stepped attenuator), it seems like most people recommends a Linear pot with a value between 10-50 Kohms. Is this right? that's it
#2 |
I have Brian's kit also. I'm going to use a 330va 30v + 30v, with 8 ohm bookshelfs.
Brian recomended me the Noble pot from Percy Audio They was a thread I recently read just about pots and here it is and the heat sink idea sounds like it might be alright. But the more power, the hotter your chip gets. You may want to think of alternatives. |
#3 |
diyAudio Moderator Emeritus
these questions have been thrashed out a hundread times at least. regurgitating them here will not offer any more definitive answers, but nevertheless...
1) single lm3875 is capable of continous 56w at 8 ohms. 2) neither of those transformers is optimal. the chip ceiling is around 28v before rectification. I would suggest a 2x25 to allow for some mains variation. 3) how thick is the aluminium? If anything >= 6mm, then I would say no problem. 4) 10-50k will be fine. you will want to law-fake if using linear. with cheap pots, i feel the bigger issue is channel matching not linear vs log or R value.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#4 | |
But is 220VA enough for two channels? The aluminum is only 1-2mm so i guess i'll have to salvage something more robust. The pot i'm going to use is quite ok, it was just the value i was wondering about since i've read a couple of threads stating special values but perhaps that was for one of the inverted versions. |
#5 |
the lower rail transformers are better if you intend to use lower ohm speakers, i.e 6 or 4. Considering these are only nominal values, I can see why some people will recommend lower rails for 8 ohms+ too.
However, some people say the chip sounds best with higher voltage. Since your goal is to get max output in 8 ohms, higher voltage is what you're looking for. 220VA is enough. I find the difference in cost between 2xx and 3xx little, in which case I prefer to go for the larger. You will need a lot more than 1-2mm heatsink, especially if going for highest ouput = more voltage.
#6 |
I would suggest the 2*22V transformer. With that transformer you can expect 37W (see my measurements here. Using a too small heatsink is no problem - the chip will protect itself
![]() Just try it - if the chip switches off or starts distorting (or the box get's too hot) use a larger heatsink. Best regards, Mikkel C. Simonsen |
#7 |
mcs& Vikash:
thanks, since there's no difference in price i will go with 24V@220VA and use some heatsinks from an old computer. |
#8 |
oops, it should say 24V and 300VA.
| Help needed ! Inter M R300 schematics needed ! | alexclaire | Solid State | 30 | 9th September 2009 06:14 AM |
| High-quality power supply for a gainclone not needed ? | Blitz | Chip Amps | 35 | 1st February 2004 09:24 PM |
| help needed in designing gainclone | audioaction | Chip Amps | 14 | 31st August 2003 07:32 AM |
| Experts needed: Crazy phase issue with Inverted Gainclone | PaulHilgeman | Chip Amps | 30 | 20th February 2003 06:06 AM |
| Page generated in 0.09546 seconds (77.58% PHP - 22.42% MySQL) with 10 queries |
