Old 29th November 2004, 01:51 PM   #1
B.I.G is offline B.I.G  Romania
Angry heat pipe problem
i have a heat pipe on my LM3886 GC and it sometimes stop conducting heat and the LM`s get hot >> spike protection !
if i shake the heatsink a little it starts working ! can anything be done to restore it ?
i really like it
B.I.G
Old 29th November 2004, 02:11 PM   #2
wimms is offline wimms  Estonia
Too much heat for given heatpipe?
Old 29th November 2004, 02:14 PM   #3
no i don`t think so because when it works it doesn`t get to hot it is just warm .... that`s why i wouldn`t like to change it .
when it doesn`t work the part where the chips are installed get`s very hot and the part where the fins are is cold .
B.I.G
Old 29th November 2004, 02:23 PM   #4
Thats the working principle. When it works, its barely warm. When it fails to conduct heat, it disconnects heat source and sink. This happens when working fluid boils and can't condense. Shaking indeed might trigger condensation.
I assume you have your heatpipe physically installed correctly, and ambient temperature is right for it.
Old 29th November 2004, 05:42 PM   #5
ir is offline ir  New Zealand
Send a message via ICQ to ir
sounds like the cooling at the other end is insufficient. is it just a heatsink or a heatsink+fan? remember of course, the heatsink at the other end should have the same C/W rating as a heatsink you'd mount the amp IC to directly. the heatpipe simply efficiently moves the heat away from the source, the chips heatsink requirements therefore remain the same
LM4780 Heat problem Niila Chip Amps 15 2nd December 2006 08:16 PM
A3 heat dissipation problem spTOH Pass Labs 4 3rd October 2006 05:45 AM
heat sink problem k1jroth Solid State 12 24th March 2006 07:34 AM
heat problem or not ?? arold19 Pass Labs 11 3rd May 2004 01:37 PM
Yet another heat sink problem OliverD Pass Labs 10 16th October 2003 05:29 AM
Page generated in 0.08114 seconds (73.39% PHP - 26.61% MySQL) with 10 queries
