| Chip Amps Amplifiers based on integrated circuits |
hi
i've been searching diagrams for opa 509 but havnt found any. can i use the schematics of the inverted lm3875 and just replace it with opa 509? what voltage trafo should i use here. thanks |
#2 | |
You can use the same 3875 schematics, but not the resistors values. On a recent thread there were some comments on these OPA chips needing less gain, as their bandwidth is smaller than the LMs. 100K and 10K might do the job, but be prepared to listen to the system and change the larger resistor for a smaller (or higher) one and listen to what does change. Carlos |
#3 |
the opa549 schematics are a little different as they have an optional current limiting resistor and diodes for protection purposes.
if only it could be used for good, not evil... |
#4 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 | |
It should be fine |
#6 |
The 220k resistor can be SMD
.Miguel |
| Can someone look at this diagram for me? | warnsey | Full Range | 5 | 31st May 2006 01:21 AM |
| LM3875 pin out diagram | Nordic | Chip Amps | 2 | 21st September 2005 08:37 AM |
| Help! circuit diagram | vodaTube | Tubes / Valves | 0 | 8th July 2005 06:49 AM |
| B&W 801/802 diagram | aarsoe | Multi-Way | 5 | 28th March 2005 05:16 PM |
| Diagram of B&W CM2 | klitgt | Multi-Way | 0 | 28th November 2004 08:38 PM |
| Page generated in 0.07921 seconds (74.64% PHP - 25.36% MySQL) with 10 queries |
