loud hum w/ 1st Gainclone loud hum w/ 1st Gainclone - Page 2 - diyAudio
Old 30th November 2004, 08:24 AM   #11
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Bret, you may also have a break in the negative voltage rail to that channel.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 1st December 2004, 04:16 AM   #12
JazzzSpazzz is offline JazzzSpazzz  United States
First, thanks for responding--I really appreciate the help!
Well, it seems that the bottom of the board looks clean--no shorts are visible. The board is BrianGT's and the V- & IN & OUT holes are separated--I also checked V+ & IN & OUT--no visible connections. So it doesn't appear to be shorted. The voltage is actually -35VDC not +35--sorry, my bad typing.
Nuuk, I did continuity checks with the power off between the V-, V+, PG-, & PG+ of the right (bad) channel to the left (good) channel. It showed 0 Ohms for each set (e.g. V- of Right to V- of Left). I think this should have checked for any break in the power rails & it looks like they are intact.
Any other test to look at? I've gone over the wires about 50 time & they are fine. I can't see a short on the board, but I'm at a loss to figure out why they huge DC offset. It seems as if it has to be a short between V- & In or OUT. The chip is not even the slightest bit warm, but I am only turning it on for a minute or so to test. Could the chip just be bad?
TIA,
Bret Morrow
Old 1st December 2004, 07:00 AM   #13
boholm is offline boholm  Denmark
boholm's Avatar
Since you have tested everything thoro'ly, it does seem that the chip is dead. So:
You should try and solder out the bad chip and measure it for a short between -V and output. If this is 0 ohms then it is dead. If not then measure between -V and output on the board. If no short there, then measure the input vs. -V. If no short there then power up the board(still without the chip) and measure voltage on the input pin. If this is not 0 volts, then measure +V and -V. If they are not + and - 35 volts, then . . . Well, the chip can still be bad, so a spare could come in handy
Best regards
Bo
Old 1st December 2004, 08:01 AM   #14
Nuuk's Avatar
Do as Bo says but before you remove the chip, measure the voltages on each of the pins to check that you have both + and - 35 volts!
Old 1st December 2004, 08:16 AM   #15
m@ is offline m@  Thailand
My 0.2$'s:
In my haste to finish my first GC, I managed to mix up the signal and signal ground (the IN on Brian's board looks like an N - my anxious little brain said SG - signal, N - neutral, which makes no sense, but hey...).
This produced a nasty DC offset/buzz, but I can't remember if it was as high as 35V.
I feel your pain... But it's well worth the effort.
Old 2nd December 2004, 03:30 AM   #16
Will do. I disassembled the unit holding the amp boards & got them out of the box with wires attached. Man, was this a bad design--it looks really nice (IMO), but it is not user friendly! I'm going to bring home some narrow test probes that I have at work before I test, so I will test tommorrow (mainly because I'm tired & don't want to make a mistake). Oh, dispite having electronic test equipment at work & am rather clueless about it--I'm better on the biology end
Originally posted by m@
My 0.2$'s:
Thanks, I check & rechecked, but I can always find other ways to mess things up ;-) I have to remember the end product right now!
Bret Morrow
Old 2nd December 2004, 04:10 AM   #17
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
try and unsolder these chip would be a hard task witha dual layer board and yeah i cant see any one doing this can you ?
Old 2nd December 2004, 08:17 AM   #18
Nuuk's Avatar
I still maintain that hardwiring is the best way to build a GC for beginners as it is easier to fault find, and see (and understand) where all the parts go!
I'm not saying that PCB's are no good, just in this case I would prefer to hardwire.
Old 2nd December 2004, 01:26 PM   #19
Sorry, I was saying my design of the box BrianGT's boards were put in was the "bad design". I think the boards were simple & quick. I read your site before Brian set up the group buy and was going to get around to trying to build 1 "someday". The availablity of a "kit" made me actually get going on it sooner, rather than later (never?). I have hardwired speaker crossovers with no concern but those components are huge compared to the ones in a GC.
My box is too small. The boards & heatsink are on a platform that drops into the box--it is very snug & I didn't think enough about soldering lines from the tranny & input/outputs when I set it up. The goal was to use silicone adhevsive to secure the platform to small cleats on the sides of the box when everything works--I thought that it would make a real nice dampening system for the amp boards. It took me a good hour to get the platform out of the box, so I could remove the right side board to see its underside. The best thing I can say about it is that I still think that the box looks lovely on the outside and should work well, eventually.
I hope to test out the chip this PM.
Thanks again,
Bret
Old 3rd December 2004, 10:40 PM   #20
Default results from testing
Well, I measured to try & discover the problem, but I'm still a bit clueless. Here's what I know:
No continuity from chip pin 4 to pin 3 (-V to OUT).
No continuity from chip pin 4 to OUT on board.
No continuity from chip pin 4 to pin 7 (-V to IN).
I powered up the board & measured VDC:
...from V+ to PG+ I've got +35VDC
...from V- to PG- I've got -35VDC
...from pin 4 to board ground I've got -35VDC
...from IN to SG I've got 10.3VDC
& of course I've got -35VDC from pin 3 to OG.
The only thing that I can identify as odd is the chip, but there appears to be no apparent shorts in the chip. I emailed BrianGT telling him what I know & asking him what he thinks.
I'm thinking about desoldering the leads & listening to the left channel in mono! Stereo is so over-rated!
Bret Morrow
loud hum w/ 1st GaincloneHide this!Advertise here!
For those that like it loud RacerXtreme Multi-Way 25 12th September 2007 04:02 AM
GainClone not Loud HouRman9 Chip Amps 5 10th September 2003 03:11 AM
For those who have hum with theyr gainclone (loud or not) Bricolo Chip Amps 6 16th July 2003 07:57 PM
My Gainclone is too Loud PaulHilgeman Chip Amps 5 16th February 2003 01:02 AM
Copyright ©1999-2017 diyAudio
