Old 28th November 2004, 07:38 AM   #1
martyh is offline martyh  United States
Default Chip amp with input transformer?
Hi all,
I am new to chip amps but not to diy. I have built a few tube projects but no sand amps to date. I just ordered a LM3875 kit from chipamp.com and plan on building it with input transformers as I have a few source components with a high Zout. The transformers have a 3:1 turns ratio so a typical high output source will deliver about .5 to .7 VRMS at the input of the amp. Will the standard kit work with so low an input voltage? If not I gather that I can increase the gain by raising the value of the feedback resistor. Can anyone point me in the right direction as to a suitable value for that resistor?
Thanks in advance for any help,
Marty
Old 28th November 2004, 10:32 AM   #2
wxn is offline wxn  Lithuania
wxn's Avatar
The calculations required are very simple. Anyway, it should be fine as it is.
Nothing is as simple as it seems
Old 28th November 2004, 07:22 PM   #3
Default found it
Thanks; I found the formula in the archives. Changing the R from the neg input to ground should be a simple matter if I find I need a bit more gain
Starting a student project, need some input (chip amp + speaker set) Sneasle Chip Amps 127 16th March 2009 10:38 PM
Input transformer: floating input = distortion ErikdeBest Tubes / Valves 13 20th January 2009 09:36 AM
transformer for my chip amp? kanifee Chip Amps 34 23rd April 2008 07:46 PM
Chip amps - referencing input to negative rail? Circlotron Chip Amps 21 12th June 2004 11:16 AM
Page generated in 0.06926 seconds (83.13% PHP - 16.87% MySQL) with 10 queries
