| Chip Amps Amplifiers based on integrated circuits |
this thread is build for talking about 3886inv gainclone and assembling.any suggestion is welcomed.
feel free to post your finished gc. Series PCB design tips: AN-1192 BPA200 Application Note LM3886 DATA SHEET LM338 regulator LT108* DATA SHEET DRV134 DATA SHEET and,much information comes from Chip Amps forum,thanks everybody Pcb boards detail: BLD driver Regulaotr power supply LM3886 INV AMP The size of these three PCBs is totally the same,I like the layout style of tight & compact pattern.I think this way is mentality of designing of GAINCARD too. I have not designed the unregulated power supply PCB. If you want to assemble a PCB based unregulator igc,there are two very good unregulator pcb design: BrianGT's rectifier PCB peranders ultra fast rectifier bridge bigparsnip's ultra fast rectifier bridge cheers digi |
#2 |
3886igc and regulator psu connections.
#3 |
The file releasing
attached zip package includes 3886igc +regulator+BLDdriver,gerber output files and nc drill output files.for gerber viewer, I recommend CAMtastic,the CAMtastic DXP free viewer supports a wide range of import formats, including ODB++ and Gerber viewer... url:http://www.altium.com/camtastic/down...iewer_rego.asp enjoys digi |
#4 |
Wow, thanks.
#5 |
Banned
Going to be printed tonight and put into book : O ) thanks digi.
I also need to email you about some ideas and questions. |
#6 |
10x for sharing this with us !
B.I.G |
#7 |
to assemble an integrated stereo amp with regulator power supply.
step by step pic ![]() first,for 3886inv boards. because it is a regulated gainclone,so small caps is all right finally,I use 4x 330uf/50V silmic caps for decoupling. |
#8 |
all resistors is KOA SMD for gain setting.
#9 |
second,for regulator PCB.
pic,screw the liner regulaotr on the heatsink first. |
#10 |
then solder the big caps finally.the big caps that I used is nichicon 6800uf/50V.
| 3886 LRxover biamp speaker project... maybs kits, comments please. | ren@darkertek | Chip Amps | 5 | 10th January 2007 01:34 AM |
| PS for Brian's chipamp 3886 and 4780 | rgrayton | Chip Amps | 0 | 20th April 2005 11:39 PM |
| Page generated in 0.09350 seconds (80.97% PHP - 19.03% MySQL) with 11 queries |
