| Chip Amps Amplifiers based on integrated circuits |
#11 |
looking good! wish i could find some heatsinks like that.
"I Love To Camp!" "Comensing Shock Therapy!" |
#12 |
thank you Evilsizer
If there is not shipping problems,I am glad to help you to buy some.its price is reasonable. ok,the end pic.I am still need to find some quality wires to hook up all these patterns. |
#13 |
Can I buy the boards already printed or anything?
Looks really good, great work! |
#14 |
digi
On the 3886 IGC is there any reason why you couldn’t use a 1k/22k or a 620R/20k (for higher gain) resistor combination instead of the 10k/220k combination you specify? Would you need to change the size of the 4.7uf input capacitor if you did use the lower value resistor combinations? Out of curiosity what is the cost of the heatsinks, size, and what do they weight? Do you know what shipping would be to the states? I would like to get some balanced line driver and regulator boards (if still available) and could use the heatsinks if not too expensive. Thank you Jim |
#15 | ||
Hi Jim,
url, http://www.diyaudio.com/forums/showt...850#post322850 BTW,for a small resistors 3886 igc, P-A has a wonderful design the famous industry QRP-02 gainclone.url, http://home.swipnet.se/~w-50719/hifi/qrp02/index.html Quote:
YGPM digi |
#16 |
the picture reveal another assembly way,the liner regulator is installed on a aluminium chassis.and the diodes is shifted by a international rectifier.
#17 |
sch for this set up:http://www.diyaudio.com/forums/showt...349#post526349
#18 | |
Gigi01, Any recommendation for people with Center tap secondry instead of dual secondary output pair Transfomr?
VuAmp2 http://community.webshots.com/user/vuamp2 |
#19 |
to Vuamp2,
i c,then you have to use the unregulator solution.because NSC is not offer a passive regulator chip with high current output. edit,mistake modify. |
#20 |
I soldered up 2 of my four today. I built these two on the cheap to use with the computer. they sound great. no hum. I am happy.
I will keep updating as I put them into some cases. |
| 3886 LRxover biamp speaker project... maybs kits, comments please. | ren@darkertek | Chip Amps | 5 | 10th January 2007 01:34 AM |
| PS for Brian's chipamp 3886 and 4780 | rgrayton | Chip Amps | 0 | 20th April 2005 11:39 PM |
| Page generated in 0.09636 seconds (81.92% PHP - 18.08% MySQL) with 11 queries |
