Old 25th November 2004, 06:40 PM   #1
hihopes is offline hihopes  South Africa
Default OPA627 preamp
I am on the point of building an OPA627/BUF634p pre-amp. I have looked up some old threads and found a lot of useful info, but I am left with a couple of questions:-
1) How many BUF's sound best in a pre-amp. (I experimented with them in a headphone design and found that although TI recommend 3, this seemed to rob the sound of some air - almost a sort of compressing effect) I don't know whether they would produce the same kind of effect, and also whether the extra current would make much (or any) difference in a pre?
2) What about biasing OPA627's with a resistor? I have tried this with OPA627's on their own and liked the effect, but has anyone tried it both ways in a pre-amp with BUF634's? Carlos, perhaps?
3) Out here in the sticks, I can only get stripboard to build on. I have been through so much of the stuff it is sickening. (bits of circuit lying all over the place!) Before I waste any more board (and components), does anyone have any useful hints on working with stripboard for this kind of project?
4) One of my biggest headaches so far has been with grounding. I have even gone so far as to build a circuit with a separate wire for each possible ground (power ground, signal ground, left, right, op-amps, buffers) You can probably imagine what it looked like. You could hardly see the components under the forest of wires. My idea was to try joining them up in diffeerent combinations to see what brought about the best result. Well, it was a disaster. Not only did I learn nothing from it, I couldn't even get it to play music at all!
So please, any useful advice will be welcomed.
Thanks in anticipation,
William.
Old 25th November 2004, 08:03 PM   #2
pete.a is offline pete.a  United Kingdom
pete.a's Avatar
Default Strip Board
Hi William,
It's a wee prob trying to use strip board for this circuit, but you can obtain a reasonbly good looking design.
If you use the 100 by 150 board as iv'e done, and use the first four central strips for ground. Then i placed the regs on the outer edges for the power , well that's just one method i used , may not be the best. Then used zero link's and some cat 5 aswell.
Hope the attatched image say's more..
The large heatsink on the pos reg is due to a small prob that not even a electronic buff could work out ! Well not visually anyway.
Old 25th November 2004, 08:17 PM   #3
Shoog's Avatar
Hi there,
I built a opa627 buffer on strip board (the copperless type). I got it about half the size of pete.a 's. No problems with grounding. Two star grounds, one for each channel and then linked at a master star ground. I used basic Zener-transistor regulation, with both channels sharing the rails. I had 47uf of electro caps at the chip pins, bypassed with 1nf film caps, and with the two rails tied with a 0.47uf cap (this made a big difference). Very simple.
Worked perfectly first time and sounds lovely and detailed and smooth.
Some say that a descrete transistor circuit works better than the OPA627. I wouldn't nesscarily disagree.
Shoog
Old 25th November 2004, 08:22 PM   #4
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Default Re: OPA627 preamp
Working with stripboard is a lot easier if you start by "converting" the schematic into a building sketch with the IC's and power rails drawn in first. Then add components to the sketch one by one, use red ink to note where you have to cut the traces (a simple cross will do as well) and where to add jumpers. This will give you an idea of which tracks should be used for power and also how much spacing is necessary to fit everything in. When you've completed the sketch and double-checked to ensure that everything is correct it is quite easy to place components (start with the IC's and the jumpers to your designated power traces) and mostly you'll be able to assemble even complex circuits without mistakes. The "design-phase" of the sketch is of course quite tedious, but if you ask me it's not nearly as tedious as trouble-shooting circuits built on stripboard Use a 3,5 mm drill bit or a sharp knife to break traces.
Happy building!
/U.
Old 26th November 2004, 12:12 AM   #5
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
William.
a ground plate shoule be fine.this is my design,the board is carved by a knifeand leave big copper for ground shadel.finally,its result is very good.
Plan to make one HEADCLONE<pic>
digi
Old 26th November 2004, 12:46 AM   #6
digi01's Avatar
http://tangentsoft.net/audio/opamp-bias.html
Old 26th November 2004, 02:29 AM   #7
digi01's Avatar
for stripboard,
the blue dot is drill bit.interface has assigned on PCB's border. without power supply layout.
enjoys
digi
Old 26th November 2004, 02:58 PM   #8
Thanks for all your replies. I will studynthem and answer this evening when I have a bit more time.
Old 26th November 2004, 06:50 PM   #9
OK, now I have a moment.
Firstly, Pete.a, thanks for your pic. I will have a good look at it, but my initial feeling is that I want to build a lot more compact than you.
Hi Shooq, I can't get copperless stripboard, so I am having to make do. Thanks for the useful info. I assume your "master"star ground is to the chassis, (or not)? Are you using a metal or plastic enclosure, and is your chassis connected to ground in any way?
Where exactly did you tie the rails with 0.47uF? I have seen it recommended to tie them across the Vcc pins of the op-amps and was intending to do that, but with much smaller caps (100nF Wima poly).
Old 26th November 2004, 07:07 PM   #10
Hi Nisbeth,
I agree with you about the drawing. I have used Coreldraw to plan my layouts and probably spent a lot more time drawing than soldering.
Digi01, thanks for all the tips and info and especially for the stripboard layout. I had a totally different idea (To place the buffer "above" the opamp in each channel. I never considered placing tham next to each other. Will have a good look at your design. Perhaps after building in stripboard, I will try one like you did by carving. Looks cool!
Thanks for the e-mails Per-Anders and Dr. H.
Per-Anders, thank you, I have had a good look at your QRV04. It looks excellent (as do all your designs I have seen). I can learn some things from it, but it is obviously made for a PCB and surface-mount components rather than for strip-board. The postage alone for one of your PCB's would kill me.
Dr.H, thanks for the very kind offer. Reply sent by e-mail.
opa627 schematic for preamp fernmeister Instruments and Amps 3 6th February 2010 04:51 PM
OPA627 Buffer Based Preamp ianpengelly Solid State 30 27th January 2010 12:04 PM
OPA627 + BUF634 Preamp PCB Design Alcaid Solid State 109 22nd June 2005 01:08 PM
Page generated in 0.13896 seconds (81.50% PHP - 18.50% MySQL) with 11 queries
