Old 24th November 2004, 05:41 AM   #1
duffy is offline duffy  New Zealand
Default Input transformers and IC input impedances
I want to use a Lundahl LL1550 transformer as a stepdown/splitter 4:1+1 as shown as *connection F* in the this datasheet:
http://www.lundahl.se/pdfs/datash/1550.pdf
I want two outputs so I can run power IC's with active XO inputs for my Jordan JX92s/Aurum Cantus G2Si speakers. Tenatively thinking of an inverted LM3785 on the ribbon and inverted, bridged LM3886's on the cones @ 4500Hz XO or so. I intend to try all the possiblities for comparison.
My simple question is this:
Assuming I load each secondary with a 5k resistor (or 2k5 + 2k5 for the balanced, bridged connection) I will have 160k ohm input resistance. But what does the IC *see*? In other words, does the IC *see* 5k or must I add a series resistor for the IC input in order to define the feedback ratio?
Secondly does the secondaries static resistance play any effect, or is it swamped out by the loading resistor?
Thanks, duffy
Old 24th November 2004, 08:22 PM   #2
TwoSpoons's Avatar
At DC your chip input will see the DC resistance of the secondary.
At any other frequency it will see the seondary inductance in parallel with the 5k and in parallel with 1/16th of your source impedance. Roughly.
Old 25th November 2004, 06:35 AM   #3
Thanks for the reply Two Spoons,
Exactly what I was looking for.
Thanks,
Duffy, (Kiwi in crazy Tokyo)
Old 25th November 2004, 07:59 PM   #4
TwoSpoons's Avatar
Ah! That would explain the flag!
Old 2nd December 2004, 06:08 AM   #5
Default IT / attenuators / impedance
I thought about your answer for a couple of days, Two Spoons, and decided that I was still confused (as always!). To make sure, Two Spoons, or anyone else, for that matter,
1, Is the feedback ratio defined as:
Rf/Rin or
Rf/Rin ll secondary inductance ll source impedance*step down ratio squared
(by inductance you are refering to idle inductance??)
If it's the latter, then assuming a high source impedance of 10K, then effective Rin is around 600ohm, and the ratio is very subsceptible to changes in source. In this case, I guess the smartest thing to do is to load the tx primary with a high 100K pot?
2, Separately, if it's the former,!=@does it make sense to vary Rin to use as a volume control? I assume this is what a series attenuator is. For example, if Rf is 220K, could a 12 step attenuantor be sometime like:
Rin 5K, 10K, 20K, 40K, 80K, 160K, ....etc
I realise these are not log values, but you get the idea.
Comments?
Input transformers tiroth Parts 30 12th April 2012 06:48 PM
Simple ReAmp Mod? Help with Input Impedances, Please! slor Tubes / Valves 7 17th March 2008 07:56 PM
Op-amp input impedances and a pot/attenuator breez Chip Amps 5 1st February 2005 01:17 PM
line input impedances? Dominique Parts 5 5th August 2004 11:19 AM
How does a summing circuit work in terms of input/output impedances? Saurav Everything Else 3 16th May 2003 04:10 PM
Page generated in 0.07985 seconds (76.27% PHP - 23.73% MySQL) with 10 queries
