| Chip Amps Amplifiers based on integrated circuits |
My NIGC is almost done, but I need to be sure that my power supply board is OK. When I measure the voltage from V+ to +PGND on my power supply board, I get 73V I was wondering if it's OK I use a Plitron toroidal transformer (2 x 22V @300VA). Thanks for your help
Daniel |
#2 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
I'm still puzzled how it's even possible with a transformer you have, unless you connected secondaries in series?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 |
Actually, each rail should be about 31-32 VDC. It does seem strange that you have 73!
Disconnect the PSU section from the PCB and measure your voltages (AC) after the trasnformer, then the rails coming off the rectifiers bridges.
#5 |
And remove those 50V rated capacitors from the board
#6 | |
I already took some measure after the transformer and I got 24VAC (I dont understand why I don't get 22). When reading your post, Ijust saw that you said 31-32 VDC. When I said 73V, it was 73 VAC ..... Maybe a beginner mistake Please let me know if I should measure the VDC instead of the VAC ! Thanks !
Daniel |
#7 | |
No, they are not connectec in series Regards,
Daniel |
#8 | |
Yes, after the rectifier bridge which changes the AC into DC, you should be measuring with your meter set to DC.
#9 | |
I took the time to read a part of your guide and the answer to my question was there I will finish to read it and this will prevent me from asking other basic questions Thanks a lot !
Daniel |
#10 | |
Hi, I have a last question. The power supply board is already connected to the each channel PCB. I could cut the wire to measure the VDC, but I'm wondering if the measures I took (3 days ago) from V+ to +PGND and V- to -PGND (both 73VAC) could tell me that the power supply is well assembled ? (It's a very simple assembly and I really dont think that I maid a mistake) Any possibble calculation that I could use If not, I'll cut the wire Thanks again ! Daniel
Daniel |
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| Question about CT transformer and Brian's Rev C power supply board | maurycy | Chip Amps | 9 | 8th December 2009 09:21 AM |
| Brian gt chip amp power supply? | guycom | Chip Amps | 4 | 29th September 2008 09:57 PM |
| Beautiful power supply! Brian's Chipamp.com | danielwritesbac | Chip Amps | 34 | 28th January 2008 04:44 AM |
| Brian GT Gainclone Watts/Ch & Power Supply | lgreen | Chip Amps | 5 | 14th April 2005 07:04 PM |
| Page generated in 0.12445 seconds (77.69% PHP - 22.31% MySQL) with 10 queries |
