Old 23rd November 2004, 06:39 AM   #1
D_GR8_1 is offline D_GR8_1  Australia
D_GR8_1's Avatar
Default MUR Bridge on a PCB
Im making a Reg PSU PCB and I am trying to implement it on a one sided design.
However, I am having trouble with the bridge connections.
Whichever way I connect they seem to overlap.
What's the easiest way of doing this?
Old 23rd November 2004, 06:48 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
I don't know exactly what you mean but do you mean that you can't solve it without jumper wires? Do you have a picture of your efforts so far?
/Per-Anders (my first name) or P-A as my friends call me
Old 23rd November 2004, 06:51 AM   #3
D_GR8_1's Avatar
Default PCB
I was hoping not to use jumpers.
Old 23rd November 2004, 06:55 AM   #4
peranders's Avatar
Why don't you just move the diodes a bit? If you don't plan any additional cooling you can also twist the diodes so it makes it easier for you.
Old 23rd November 2004, 06:57 AM   #5
D_GR8_1's Avatar
Default how
That's exactly the question of my post.
How do I arrange the diodes?
Old 23rd November 2004, 10:28 AM   #6
D_GR8_1's Avatar
Default No one has designed a PSU PCB before
No one can give me any ideas on how to position the diodes?
Old 23rd November 2004, 10:41 AM   #7
Did it Himself
richie00boy's Avatar
It's pretty simple Just copy a 'block' high current bridge.
Old 23rd November 2004, 11:40 AM   #8
D_GR8_1's Avatar
What do you mean?
I have 4 single diodes, not 1 diode bridge.
Also, I am trying to avoid making the PCB double sided.
Old 23rd November 2004, 12:18 PM   #9
peranders's Avatar
If it makes it easier for you, draw all traces frist and then move the diodes.
Think how a rectifier bridge looks like, the convert it to four separate diodes.
Old 23rd November 2004, 09:00 PM   #10
D_GR8_1's Avatar
peranders, I have done that. I even tried placing traces under the actual diode, but the trace width that I use (5-10mm) actually doesnt make this possible.
What I am asking for is for someone who has already done this to post a picture of it or something.
Full Bridge X Half Bridge: What's The Best? CHACALPOWERS Power Supplies 8 18th July 2008 04:45 PM
Reopening an unfinished debate: Dual bridge vs. Single Bridge xiphmont Chip Amps 15 26th February 2008 07:22 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Page generated in 0.09629 seconds (74.59% PHP - 25.41% MySQL) with 11 queries
