Old 23rd November 2004, 03:23 AM   #1
jsteigs is offline jsteigs  Japan
Default lm3875 problem
I'm using the lm3875 circuit off of decibel dungeon and i get the circuit to work but it doesn't sound like 50W. Any ideas why this could be? this is my first GC but i have built other stuffs.
Old 23rd November 2004, 04:07 AM   #2
Send a message via ICQ to rampage101 Send a message via MSN to rampage101
Have you checked all resistors are correct? What source are you running from?
What's a signiture?
Old 24th November 2004, 09:24 AM   #3
yes, all the resistors are correct and i have a 40VCT (40-0-40) supply.
Old 24th November 2004, 09:29 AM   #4
UrSv is offline UrSv  Sweden
UrSv's Avatar
40 VCT (40-0-40), what exactly is that? A transformer with a 80 VAC transformer with a center tap i.e. two 40 VAC secondaries or do you mean that you have +/- 40 VDC?
If it doesn't sound like 50 W are you sure you are driving it to the level where it would?
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 24th November 2004, 09:35 AM   #5
Sounding is a very vague term.
It will depend on how efficient is the speaker system you are using, what type of speaker it is, what source you are using, the room the speakers are in, your perception on what is loud, etc.
There's an exact way to quantify that, which is using a load (4 or 8 ohm) and an oscilloscope, inject an AC signal and see how many volts you get before clipping. As simple as that.
Carlos
Old 24th November 2004, 11:39 AM   #6
mcs is offline mcs  Denmark
Default Re: lm3875 problem
How does 50W sound? I have tested the output power on my amp (see the results here: http://stiftsbogtrykkeriet.dk/~mcs/LM3875/index.html), and I get 37W with a 2*22V transformer. So 50W should be possible to get if you have a 2*40V DC power supply.
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 24th November 2004, 02:03 PM   #7
jackinnj's Avatar
Default Re: Re: lm3875 problem
Best regards,
Mikkel C. Simonsen
+/- 40VDC has too little headroom for the LM3875 -- you may be causing the chip to go into its protection mode, and if its a 40-0-40 transformer you are way over the bounds for the chip as this will (should) produce +/-56VDC.
Old 24th November 2004, 02:08 PM   #8
It can't be a 40-0-40 transformer.
There is no dobut 112VDC would fry the chip. The absolute max is 84VDC.
Old 24th November 2004, 02:10 PM   #9
Electrons are yellow and more is better!
peranders's Avatar
Max voltage is 2 x 28 VAC and 2 x 24 V seems to be "normal".
50W is more or less peak power so you have very little headroom. If you are using a 4 ohm speaker and high voltage the poor LM3875 has a hard time to deliver max power.
Notice also that the LM3886 has substantially more current capability which is good for the sound quality especially if you have heavy speakers.
/Per-Anders (my first name) or P-A as my friends call me
Old 24th November 2004, 04:12 PM   #10
peranders,
max voltage is 84V, so +/-42VDC.
How do you get +/-28?
LM3875 gainclone problem cjv998 Chip Amps 25 16th August 2007 12:57 PM
LM3875 amp problem sebtdi Chip Amps 6 12th July 2007 07:23 AM
Hum problem with LM3875 GC!! w00t Chip Amps 26 19th October 2004 09:36 PM
:: Lm3875 Gc Problem :: audioPT Chip Amps 7 15th October 2004 02:03 PM
LM3875 Problem nitin Chip Amps 0 23rd September 2004 07:40 AM
Page generated in 0.16513 seconds (59.96% PHP - 40.04% MySQL) with 10 queries
