Old 22nd November 2004, 05:41 AM   #1
rs1026 is offline rs1026  India
Default Spliting the input signal?
First of all I would like to thank all the members of this forum for all the help.It is from here that I derived my inspiration to design my own PCB for lm3886 based amp.After going through all these forums.(I took some 2-3 months just to see whats going on here)I designed my own PCB,it was a good design in the sense there is absoulutely no hum.Having built one channel I moved on to build another channel and now I have a good sounding lm3886 based amp capable of driving two channels.
Having come till here I want to go one step further by adding a sub woofer.But I have a doubt.
At present the way I am using my amps is I am spliting the signal from the input source. My input sources are viz.
line out of PC,head phone output of CD player and TV.I dont have a pre amp and I dont want to build a pre amp immediately.I swtich these sources manually i.e i just disconnect the wires from one source and connect it to other source.
The input from these sources comes through a (1+1)sheilded wire.And inside the amp chasis I am taking prallel connection to drive two channels.So from outside it looks like just a single wire is going into the amp chasis and at the output I have coonectors for hooking the speakers.
Now my question is can I use similar method and hook a sub woofer in similar fashion.I will use a dedicated amp and a filter for the sub.But the input signal will still be from any of the sources mentioned above.I will take a parallel connection to drive a sub.
To summarize input comes from PC/TV/CD player I will take parallel connections to drive two channels and a sub woofer.
Can some one please let me know if the input signal can be split this way is there a better way to do this. Please give me your inputs.
Old 23rd November 2004, 10:23 AM   #2
U will have to assemble a subwoofer filter for connecting ur subwoofer amp.
The subwoofer amp has to be atleast 3 to 4 times more powerful in Wattage than the other amp(s)
Old 18th April 2007, 01:12 AM   #3
Unhappy Sorry to revive an old thread
hi there,
sorry to revive an old thread, but I thought that'd be a better option than creating an entirely new one.
I have a problem that is somewhat related (I believe). I'm not using any DIY components, but I have an input split question.
I have a multi-input receiver that I'm using to drive DVD, VCR, TV, PC.
The TV only has a mono audio out signal. Is there any electronic reason that I can't simply split this signal and feed it into both the left and right inputs of the receiver. I know you shouldn't connect to outputs together, but I can't think of any reason that 2 inputs can't be connected.
Just thought I'd check for sure before I connect to my receiver.
Thanks.
You can only be young once, but you can always be immature.
Old 18th April 2007, 04:11 AM   #4
It is allowed and nothing will go wrong.
Gajanan phadte
Old 18th April 2007, 04:12 AM   #5
Gajanan phadte
cheers mate
Level of the input signal Progg70 Analog Line Level 2 27th August 2005 04:51 PM
CDP output signal too strong for AMP input?? Florian Digital Source 12 3rd August 2005 11:41 PM
Shielded cable for input signal falcott Parts 2 5th September 2004 02:45 AM
Input signal Odysei Pass Labs 16 15th June 2004 03:46 PM
1V to 5V input signal Dj BASS AMP Solid State 9 13th August 2003 01:16 PM
Page generated in 0.10172 seconds (67.09% PHP - 32.91% MySQL) with 10 queries
