Old 21st November 2004, 04:04 PM   #1
kinser is offline kinser  Israel
kinser's Avatar
Send a message via ICQ to kinser Send a message via MSN to kinser
Default Lm7812/7912
Hi to all,
I am in the last step of finishing my OPA541 (bridged 2 op amps) based subwoofer amp....
and now I need 12vdc +/- for the active filter and fan for the heatsink.
Now my power supply is 36.6vdc and i would like to use the LM7812/7912 regulators, but on the datasheet its writen that the max input volatge is 35v
I dont whant to use a small transformer for it...
can I use these regulators? if not maby i could use the LM317/337?
Thanks,
Kinser
Old 21st November 2004, 04:40 PM   #2
kinser's Avatar
Noooooo one?
Kinser
Old 21st November 2004, 05:24 PM   #3
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Since you are using the regulators on a low power circuit, why don't you just put a 5W or so resistor in series with the input of the regulator to drop the input voltage?
The power of Science compels you!
Old 21st November 2004, 05:27 PM   #4
Reklats is offline Reklats  United States
Send a message via AIM to Reklats
I'm not sure about the 337, but the 317 datasheet says that the maximum "input-output voltage differential" is 40v, so it seems like it would work.
Old 21st November 2004, 06:28 PM   #5
kinser's Avatar
so i can put 5w resistor, how many ohms?
and about he 317 - can i use it on the negative rail also?
Thanks,
Kinser
Old 21st November 2004, 06:59 PM   #6
Electrons are yellow and more is better!
peranders's Avatar
If you have 35-37 volts is real life I wouldn't be afraid to use 7x12 regulators but as said above you can burn away a few volts with series resistors or you could use LM3x7 which only have the voltage restriction from input to out, not ground. If you are lazy to calculate you can check my QRP02 or QRV07 amps. I use +-12 Volts LM317/337 in those designs.
If it was a commercial product I would not chose to have more than 35 volts worst case as input voltage. Then I would have played it safe.
/Per-Anders (my first name) or P-A as my friends call me
Old 21st November 2004, 07:00 PM   #7
HFGuy is offline HFGuy  Canada
use an LM317 with a bypass transistor. Dont use a resistor , its wasteful and kinda stupid
Old 21st November 2004, 07:14 PM   #8
peranders's Avatar
HFGuy, I think you misunderstood. The load was only a couple of opamps for an active filter. Not a heavy load.
Old 21st November 2004, 07:25 PM   #9
kinser's Avatar
ok, I just was notified that I need this amp finished in two days...
So I wont have time to go get the lm337/317 because I nee to go to Tel-Aviv to get the parts and i got shcool, i only have the lm7x12, and resistors i can get from a friend. should the resistors be 5-10W and between 80 to 800 ohm?
Thanks,
Kinser
Old 22nd November 2004, 09:55 AM   #10
Using a series of RC filters before the regulator, whatever the type you are using, is always a good idea.
To better implement it you should use a large capacitor, with no series resistor, after the regulator. Works very good.
Of course use separate bridges for this low current supply, not the same as the GC.
Carlos
LM7812 Test, PSRR 60dB at 100Hz ripple lineup Power Supplies 7 6th November 2006 02:12 AM
7812 vs 7912 KU40 Solid State 4 13th June 2006 03:30 PM
7912 needing minimal load? Pierre Power Supplies 3 25th May 2006 12:28 PM
lm7812-22v/2A in? reever Parts 4 21st April 2005 12:20 PM
7812/7912 regulator questions Solid Snake Solid State 48 1st December 2003 05:42 PM
Page generated in 0.10506 seconds (78.01% PHP - 21.99% MySQL) with 10 queries
