Old 31st December 2005, 01:45 PM   #611
Send a message via AIM to safetyman Send a message via MSN to safetyman Send a message via Yahoo to safetyman
Carlos, sorry have not got the time to do it. Gotta pull the amp out of the car and dismantle many many many screws b4 I can get to the chip. Once I get the chance I'll do it and let you know.
Can you be kind enough to explain what the difference will be between parallel and bridging a LM4780? What would be the situation where one would be more preferable than the other?
Thanks and a Happy & Fantastic 2006 to all.
Shehzad
Aleph 3 - Diehard fan
Old 25th January 2006, 02:30 AM   #612
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Good replacment for BB OPA 2604/604
Originally posted by Gasho
Better OPs that have same type of pacage and are double/single version like 2064/604?? Sugestions wanted
I would say OPA2134/134 is a good replacement.
It is JFET Op-Amps.
Price is not too different.
What will you use them for?
lineup
Old 30th January 2006, 02:04 PM   #613
KT is offline KT  United States
I have a Chord SPA-1800 preamp that I'm starting to mod.
It has a single ended analog gain stage that's built around the OPA604. I'm going to replace these with either the OPA627 or AD843.
From there, the signal goes to balanced output transmitter which is based on the NE5532.
From there, each leg of the signal goes to a OPA604 before it gets outputed (4 OPA604's at the ouput, one each for left and right + and - signals). I haven't looked closely at this output stage, so I'm not sure if the last OPA604's are in the signal path or if they're some sort of correction servos. I'll probably replace these, as well, maybe with AD843's or OPA627.
My question is, is there a better alternative to the NE5532 for the balanced output transmitter? I've just started researching how this works, so I don't know how much of a factor the opamp is in this position versus an analog gain stage.
Thanks for your help.
KT
Old 27th September 2006, 04:34 PM   #614
percy is offline percy  United States
Default AD8397
Reviving this old thread to see if anyone has any comments for the AD8397. Seems to be getting a lot of attention from the headphone amp folks.
Old 27th September 2006, 09:48 PM   #615
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Is there a single opamp version of AD8397?
Regards Åke
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bstleve
B/B 2604 upgrade. gasman Digital Source 32 12th March 2008 08:51 PM
Wtb Opa2134, 2604 Andypairo Swap Meet 2 6th July 2005 06:51 PM
Good replacment for TL081C odysseyvn Chip Amps 3 3rd May 2005 07:05 AM
Page generated in 0.10224 seconds (71.08% PHP - 28.92% MySQL) with 11 queries
