| Chip Amps Amplifiers based on integrated circuits |
#481 |
Carlos,
What PSU capacitors do you use for the AD815? Transformer rating? You awoke my interest for an active. |
#482 | |
But apparently the parallel capacitor can introduce noise as well. That's why a 'soft recovery' fast diode without bypass is preferred. This is just repeating what I've read, nothing more.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. --- Douglas Adams |
#483 | |
Banned
Philips 68uf + 100nf film. I use a 400ma 2x17v toroid, but anything around 2x15v at 300~500ma will do. Regulate for +/-15V. I must warn you that if you never worked with current-feedback op-amps this will be a tough one. |
#484 |
please elaborate on this carlos, after all you are responible for me ordering a pair..
#485 | |
Banned
Starts here: (re)searching for a better preamp Schematic here: http://www.diyaudio.com/forums/showt...255#post480255 Don't ask me too many questions, because it's all there. ![]() PS: I'm using the direct output, without the coupling caps. It has some DC-offset, but sounds better. I have input coupling caps on my power amps. |
#486 |
Carlos, like a true gentleman, i must say.
Didn't know about that thread. time for some info diggi'n.. |
#487 | |
could you address this post please? A few posts ago, you recommended fast diodes without bypasses because 'they don't need them'. What is your explenation for that? Hans.
#488 |
Carlos,
Pity you did not use an integrator to null the offset, is far more effective(=0.1mV offset). Like they use in power amps to avoid the offset caused by the resistor to ground in the negative feedback(=gain) path. Anyway, the AD815 has a lot of offset. This has to be dealt with to avoid the coupling caps. |
#489 | |
How would that go? Maybe an example... Thanks, LarryO |
#490 | |
From the output of the power amp. take a 1M resistor to the - of the opamp, + (opamp) to ground, 470nF from - (opamp)to the output(opamp), from opamp output to the + input of the poweramp through 2x 1M8 resistors in series where in the middle of the 2x 1M8 resitors is a 100Nf to ground to take all the spurious HF components away. Don't forget to put 2 prot. diodes on the - of the opamp to protect it from going to the full supply rail voltage of the power amp. Opamp can be any modern 741 like type. |
| B/B 2604 upgrade. | gasman | Digital Source | 32 | 12th March 2008 07:51 PM |
| Wtb Opa2134, 2604 | Andypairo | Swap Meet | 2 | 6th July 2005 05:51 PM |
| Good replacment for TL081C | odysseyvn | Chip Amps | 3 | 3rd May 2005 06:05 AM |
| Page generated in 0.11775 seconds (81.22% PHP - 18.78% MySQL) with 11 queries |
