| Chip Amps Amplifiers based on integrated circuits |
#21 | |
Location: Where the rain does fall but the trees grow tall
If you have a clock radio made in Japan in the 80's you can take it apart and look. There is a good chance there is one in there. The application is recreating a vintage guitar effect box. |
#22 | |
http://www.diyaudio.com/forums/showt...ht=#post532582 |
#23 | |
Ok, one thread I knew (VSPS) and I found a few others (So thousands or even hundreds is a bit anyway between 22 and 100uf it should be according you (I have 470uF now). Cannot find a quick mentioning of quality so I'll get some decent but not extremely expensive. Thanks moving elctron, I just found it at the same time you poste. |
#24 | |
Banned
Ok, tens. Check out what I say about the bass. Doesn't matter, put the right caps on the right places and full speed ahead. |
#25 | |
Sorry try again. I have the bypass caps right at the pins: 47uF electrolytics with 0.1uF films from the supply pins to ground. Perhaps you are influenced more by datasheets then by your own ears. |
#26 | |
#27 | |
Perhaps LM317/337 simply don't get along well with the 2132. |
#28 | |
Banned
Most datasheets say the electrolythics can be shared between the op-amps and at some distance, with small caps on the pins. This is completely wrong, it sounds nasty. You have a problem with the layout and/or the PSU and you think it's the op-amp. The OPA2132 is quite demanding at that, as is the OPA627/37. Try the LM6172 on that circuit. |
#29 | |
Banned
#30 | |
| B/B 2604 upgrade. | gasman | Digital Source | 32 | 12th March 2008 08:51 PM |
| Wtb Opa2134, 2604 | Andypairo | Swap Meet | 2 | 6th July 2005 06:51 PM |
| Good replacment for TL081C | odysseyvn | Chip Amps | 3 | 3rd May 2005 07:05 AM |
| Page generated in 0.11208 seconds (81.03% PHP - 18.97% MySQL) with 11 queries |
