| Chip Amps Amplifiers based on integrated circuits |
Has anyone tried paralleling 5 1uf black gate type n's instead of just using one 4.7 value unit. I am tempted to try it, should lower inductance and the cost wouldn't be too much to try. Any experimenters out there??????????
#2 |
I used to parallel caps like that (although of different values) but once read that it can smear the sound.
I don't know that my experiences supported that theory but these days, often for reasons of space, I prefer to go with a single 4.7 uF polypropylene cap.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
In my experience 5 x 1u will never sound as good as a single cap, especially for BG and for coupling.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 |
To Peter : I don't belive, but what is your explanation ?
#5 |
The slight variation in caps will result in multiple discharge times smearing the signal over a very small timespan.
If it sounds good... it is good! |
#6 | |
#7 |
anyone tried using bg hi-q as a bypass cap with bg nx as output cap or super e-caps using hi-q as output cap? thanks =)
#8 |
I tried them, but to me, N type sounds the best, both for coupling and bypas. It's more neutral, while NX and Hi-Q are softer and kinda tube like sounding.
I tried Super-E for coupling, but preferred a single cap with Non Polar print towards incoming signal (as orientation is important here) Check this thread for more info: http://www.diyaudio.com/forums/showt...500#post491500
#9 |
To Mark : Which slight variations ?
#10 | ||
To Upupa: to my comment:
![]() To everybody: I just installed BG N type 4.7u caps at the output of my new DAC and they sound so good. It's really hard to find a better sounding film cap, and frankly, I wouldn't even bother. It's no wonder that Michael Percy used to write on his site that in some circles, BGs are regarded better to ANY film cap in coupling applications
| Input transformer: floating input = distortion | ErikdeBest | Tubes / Valves | 13 | 20th January 2009 09:36 AM |
| Class D input LM311 Inverting input | zox2003 | Class D | 1 | 1st February 2008 07:48 AM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| convert Quad44 radio input to CD input | jives11 | Solid State | 11 | 5th March 2005 02:33 PM |
| Resistor-Input vs. Choke-Input vs. Cap.Multip. | Blitz | Pass Labs | 13 | 26th September 2003 04:59 AM |
| Page generated in 0.10224 seconds (84.12% PHP - 15.88% MySQL) with 10 queries |
