Old 18th November 2004, 04:43 AM   #1
Default input jack insulation?
what are you guys doing out there to isolate your RCA jacks from the chassis? all of the jacks that I have seen do not have any type of sleeve or collar for insulation. should i worry too much about isolating them or not? i have the brian gt PCB's.
thanks - Greg
Old 18th November 2004, 07:40 AM   #2
Default Re: input jack insulation?
thanks -
Isolating your RCA jacks, when you use a metal case, is not an option. It's a demand.
If you don't it's the sure way to a ground loop.
What jacks have you seen that have no insulation sleeves? Radio Shack?
Serious RCA connectors should have isolators, like this:
http://www.partsexpress.com/pe/showd...umber=091-1120
Parts should be non-magnetic too. Teflon dielectric is also to be preferred, instead of plastic. Pick a good RCA connector for your cables.
Carlos
Old 18th November 2004, 08:29 AM   #3
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
The alternative is to cut an aperture in the case and then use some non-conductive material to make a panel on which to mount the RCA sockets. That's what I usally do myself.
You can just see what I mean in this picture.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 18th November 2004, 10:11 AM   #4
Banned
Hi Nuuk,
What are those orange things?
Old 18th November 2004, 10:20 AM   #5
Nuuk's Avatar
They are red Carlos!
And top secret too! Sorry but I have given my word not to talk about them.
Old 18th November 2004, 11:12 AM   #6
Banned
I knew this laptop was fake...
A man's word is a man's word.
Are you into some tunning?
http://www.diyaudio.com/forums/showt...829#post514829
Old 18th November 2004, 12:21 PM   #7
Nuuk's Avatar
Tunning?
Old 18th November 2004, 01:18 PM   #8
Banned
Tunning?
Or tuning?
Those guys that tweak their cars no end...
Old 18th November 2004, 01:52 PM   #9
Mr Evil is offline Mr Evil  United Kingdom
[B]The alternative is to cut an aperture in the case...
I would consider that a last resort, sa you will lose the benefit of shielding from the case at wavelengths smaller than the hole.
https://mrevil.asvachin.eu/
Old 18th November 2004, 02:16 PM   #10
Nylon washers work fine. You just might find one with a little collar that will fit in the drilled hole and keep the jack from wollowing around the hole. Plumbing parts... like replacement washers and seats for faucets are a decent hunting ground.
Input jack replacement Crate BT-350 tonynorie Solid State 6 30th December 2008 11:57 PM
2 Mono Jack to Female Stereo Jack JellyMan Everything Else 2 27th May 2008 03:39 PM
Old phillips car amps with din input jack IrishboyM4 Car Audio 6 11th October 2007 03:29 AM
NAD 3020 input jack problem ychousa Solid State 4 8th February 2007 05:52 PM
guitar amp input jack help BelieveInKarma Tubes / Valves 16 30th December 2003 04:44 PM
Page generated in 0.11599 seconds (80.93% PHP - 19.07% MySQL) with 10 queries
