| Chip Amps Amplifiers based on integrated circuits |
Hello this is active crossover which iv designed for my
ventd movie subwoofer. Could someone better in elektronics theck it out and tell wich mistakes iv made. |
#2 |
Did it Himself
Pretty good
You just need to look at some of the component values.Some resistors are 4k or less. Try scaling your values to get these up a little as the TL07x starts struggling around 2k. The 1k output resistors are much too large and will cause noise and slight output attenuation/load intolerance, 47-150 ohms will be fine. |
#3 |
added picture of filter
#4 |
Banned
You need to add a resistor from +IN to ground, on the input of the first stage.
Those pots to set the lowpass frequency should be linear, not log. |
#5 |
Did it Himself
I would argue that the resistor at IN is optional, but if you use something like 100k it will not hurt. A
Agree with Carlos on the pot. A major flaw I missed earlier is the takeoff from the NFB point on the subsonic filter. This should be buffered else the feedback will be screwed up by the (variable as well depending on switch position, bad) loading and the filter fed from it will have skewy response as it's being driven from a relatively high source impedance. In my own designs I always buffer filter inputs. You might like to do the same (i.e. put buffer at input before subsonic) unless you can be confident that the source will always be <500 ohms or so. |
#6 | |
Banned
#7 |
Picture was old verion sorry.
I will use opa2134 as amplifier and polystyrene 1% capasitors. Is this okay. |
#8 |
Did it Himself
Yes that will cope with the lowish impedances.
Have you addressed the feedback point issue I mentioned above? |
#9 |
"You need to add a resistor from +IN to ground, on the input of the first stage.
Those pots to set the lowpass frequency should be linear, not log." The first stage is already biased via the pot and endstop resistor, adding a 100K in parallel with those will be effectively parallel with the pot/endstop and will affect the frequency and Q of teh filter towards the lower end of the frequency settings of the pot, so don't add it..... Did you mean adding the 100K from teh NC pole of S1, i.e. from the left of the 4K to ground? THAT is where you need bias for the LP filter in bypass mode. The pots should be reverse log if anything to get a decent variation range. Lukas |
#10 | |
Banned
| Active Filter Four help | Cobra2 | Solid State | 9 | 21st April 2009 11:00 AM |
| I need an active sub filter! | hernanstafe | Subwoofers | 18 | 4th December 2007 10:32 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 02:12 PM |
| Active Filter | ChevS-10 | Solid State | 4 | 24th June 2005 06:35 PM |
| looking for active filter sim | P.Lacombe | Everything Else | 0 | 2nd January 2003 10:33 PM |
| Page generated in 0.09994 seconds (79.91% PHP - 20.09% MySQL) with 11 queries |
