What type of toggle switch when driving with batteries? What type of toggle switch when driving with batteries? - diyAudio
Old 12th November 2004, 04:08 PM   #1
captain is offline captain  United States
Default What type of toggle switch when driving with batteries?
I'm in the process of designing a 3-channel LM4782 gainclone.
I'm going to power it with two 12-volt batteries connected in series.
Ground will be taken off the junction between the two batteries.
Now I'm trying to decide what kind of On/Off toggle switch for the front faceplate.
With a simple "single-pole" I could open and close the ground connection.
But, this would mean that the rails would still be in constant battery connection.
What would this do to the chip?
With a "double-pole" I could open and close the rails.
"Triple-pole" would open and close all three.
The real reason I'm asking this is that I also want to run an active cooling fan off of the same switch because I want to force the fan to be on when the amp is on.
Componding the issue is that the fan will have a high speed or low speed.
Now, this means the switch now has to become "double throw" with the fan occupying one of the available "poles" (giving a worst case total of 4 poles).
Switch Positions:
Up - amp On, fan on High.
Center - everything Off.
Down-amp On, fan on Low.
So, I know that "double throw" is needed.
But, I'm trying to determine if I can do "double pole" or "triple pole" rather than "quad pole".
I hope I've explained clearly...
I'm kind of new at this...
Thank you for any assistance.
Old 12th November 2004, 07:37 PM   #2
randytsuch is offline randytsuch
I implemented a battery powered GC with a double pole, double throw switch.
And, do you really need a fan?
I never have any heat issues, with a reasonable size heat sink.
Good luck,
Randy
Old 15th November 2004, 05:53 AM   #3
jeff mai is offline jeff mai  Australia
jeff mai's Avatar
If you use a DPDT switch on the +/- rails, you may have to try several switches. The first one I used closed the two contacts at slightly different times resulting in a loud pop at the speakers. The next switch I tried was silent.
What type of toggle switch when driving with batteries?Hide this!Advertise here!
b&k st-140 toggle switch replacement thezaman Solid State 4 11th August 2013 04:28 AM
Toggle Switch Contact Type and Rating Seraph Parts 2 12th February 2009 06:46 PM
Toggle Switch Guards??? Zero Cool Everything Else 4 11th December 2007 04:55 PM
illuminated toggle switch schumpe Parts 6 3rd July 2007 05:33 PM
toggle switch with LED on tip for t-amp mod? gychang Class D 4 18th September 2006 05:54 AM
Copyright ©1999-2017 diyAudio
