Old 12th November 2004, 03:51 PM   #1
Default recommended pots available in the UK
Calling all UK froumers
I'm thinking of building a gainclone using BrianGT's kit. Does anybody have suggestions of reasonably cheap pots available in the uk? I'm thinking of those supplied by the standard electronic components suppliers, i.e Farnell, RS, Maplin. What value should I use?
Also should I go for 18V or 25V secondaries?
Cheers
Mike
Old 12th November 2004, 04:42 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Define cheap AFAIK, www.rapidelectronics.co.uk has (had?) the alps blue for £8.50.
/U.
Old 12th November 2004, 05:27 PM   #3
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Or go for the 'best' and build a stepped attenuator!
(Approx cost 12 UKP)
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 12th November 2004, 05:50 PM   #4
mcs is offline mcs  Denmark
They are still there: http://www.rapidelectronics.co.uk/rk...9590&XPAGENO=1
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 12th November 2004, 06:07 PM   #5
Greg Erskine's Avatar
Hi parrymike,
This thread has a lot of information and opinions regarding pots.
"Silver-Carbon" Pot ex Tawan - Photo - & ignore my ugly Pinky!
The pot mentioned by Joe is available from Jaycar in the UK.
Greg Erskine
Old 12th November 2004, 06:31 PM   #6
It certainly looks like a nice pot. Pick the 20K type.
Carlos
Old 13th November 2004, 07:38 PM   #7
Thanks for all your replies.
TO Nuuk: I've just about got permission from my better other half to build the amp, there is no way she would agree to a volume control with 12 volume steps.
Does anybody have any cheaper alternatives to the ALPS pot? I must admit it does look nice.
Also, any opinions on my tranny? 18V or 25V secondaries?
Cheers
Old 13th November 2004, 08:09 PM   #8
Nuuk's Avatar
Oh dear - that is a bit of a stumbling block!
Farnell do the Piher pots but it seems that they are not much liked on this forum.
With the NIGC working best with a 20K pot, it limits the choices somewhat.
Old 13th November 2004, 08:22 PM   #9
t. is offline t.  United Kingdom
t.'s Avatar
I would go with NUUKS diy attenuator, it gives far better results than any pot including Panasonics for audio types,Noble,Alps blue etc.
I personally can't stand those Alps blue
If you want cheap then theres the R-ohm types
Old 14th November 2004, 10:16 AM   #10
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Originally posted by grege
Hi parrymike,
Jaycar are not UK based. And IME you'll be lucky if you actually receieve your order.
Cheers
I assume you're talking about the LM3875 kit in which case 18v will be better if you plan on using 4 ohm speakers. If not and/or you plan to regulate your PSU down the line then I would suggest the 25v.
I've only tried the Vishay Sfernice P11 10k pots (£4.33 from RS) and they sound good, but channel matching at the lower end ranges from bad to awful IME. I had to buy three before getting an acceptable one and I believe this is common with many cheap pots. - a problem you won't have with the stepped attenuator.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Recommended designs rockgardenlove Tubes / Valves 16 12th November 2008 01:32 PM
Recommended diy Pre for T-amp t. Class D 12 21st June 2005 09:56 AM
Alps pots vs. TKD pots? TKD worth the extra$$? G Tubes / Valves 11 17th August 2004 04:33 AM
most recommended multimeter Stefano Parts 14 25th May 2004 06:13 AM
Page generated in 0.11141 seconds (88.71% PHP - 11.29% MySQL) with 10 queries
