| Chip Amps Amplifiers based on integrated circuits |
Im about to build a 6 channel gainclone amp for an active 3 way system. I have 4780s in parrellel powering my bass drivers (120watts into 4ohms), 4780s in parrellel powering my mids, and 4780s non inverted powering my tweeters.
Is there a way to optimize each channel for the range of frequencies its playing (changing the caps or something.) I noticed on linkwitz's website that he suggests different caps for bass and treble for the 3886, so im just wondering what to do with the LM4780? Also, where is a cheap place to get aluminum? Thanks Alex |
#2 |
Alex,
I think you could optimize the different amps, but it might take some experimenting. I would play with operating voltage and capacitance, and if you are not determined to play with just one chip (nothing against the 4780), then bringing some more alternatives in might make more room for optimization. By the way, will you be filtering the signal or will you use passive XOs? |
#3 |
my xos are all active, before the amp. This is why i really want to optimize each channel for a certain frequency range.
I figure that I should probably have more filter capacitance on the bass and use the usual 1000uF on the tweeter, but im new to this and i dont really know. |
#4 | |
Using more than 10.000uF on the bass amps would be good, and 1000uF on the bass/mid amps. Carlos |
#5 | |
Banned
Do yo have pictures of your setup ? Or Schematics of your xo's ? Can i see ? |
| replacing treble/bass cut pot | rostmann | Parts | 1 | 10th August 2008 08:58 AM |
| Bass and treble control...how? | Denis.BR | Chip Amps | 21 | 30th November 2007 03:32 AM |
| Optimized double bass reflex | youyoung21147 | Full Range | 10 | 16th December 2006 06:17 PM |
| nominal bass and treble | peace brainerd | Solid State | 5 | 21st November 2005 12:41 AM |
| No bass / No Treble But Bass And treble Help! | jleaman | Analog Line Level | 11 | 29th October 2005 06:45 AM |
| Page generated in 0.09204 seconds (75.46% PHP - 24.54% MySQL) with 10 queries |
