Old 11th November 2004, 12:14 PM   #1
rs1026 is offline rs1026  India
Default lm4780 amp not working
I am not getting any sound but the heat sink is getting hot within few minutes.Could there be a short somewhere??
Old 11th November 2004, 12:39 PM   #2
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
check all your wiring and components thoroughly!
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 11th November 2004, 01:19 PM   #3
Roushon is offline Roushon  India
possibly short circuit at output stage.....
S. Roushon
Old 11th November 2004, 04:29 PM   #4
If you using a double-sided pcb, have a careful look at every solder pad on the ground plane side to see if there is any solder shorting anything.
Carlos
Old 11th November 2004, 04:43 PM   #5
Default sob sob
I am using a single sided pcb based on ukram's design.The pcb looked quite ok but some how i guess there was a short somewhere.i tried locating it through continuity testing but was unable to do it.So I thought of replacing the chip but couldnt desolder the chip properly the pcb tracks started coming out.I was put off by all this stuff so i trashed the pcb and the chip
But I have few more chips I personally feel lm4780 pcbs are not diyable.Hence I like lm3886 when it comes to this issue.
Old 11th November 2004, 06:11 PM   #6
Lsharptec1's Avatar
Any project is diyable to a resourceful DIYer. Experience tells us that often it is the simplest of things that cause problems like the one you are having.
Larry
Old 12th November 2004, 04:44 PM   #7
hilbren is offline hilbren  Netherlands
check the mute function
Old 13th November 2004, 07:28 AM   #8
juggle2 is offline juggle2  United States
I'm having the same problem...no sound, nothing.
BGT kit, dual/mono...checked connections- everything looks good. i think if it's a simple bad soldering connection one channel might work.
Assembled as per "garbage" post here. chipamp lm4780 components
but on the pcb i'm not sure which goes where as there is no documentation yet.
can someone confirm the below?
i gather the following information from other threads:
R1 = 22k (feedback resistors)
R2 = 22k (feedback resistors)
R3 = 1k or 680R (for more gain)
R4 = 22k
R5 = 1k or 680R (for more gain)
R6 = 1k or 220R (series input resistors)
R7 = 1k or 220R (series input resistors)
R8 = 0.1R (output)
R9 = 0.1R (output)
Cz1 and Cz2 seems to be the zobel cap.
the holes parallel to Cz1 and Cz2 seems to be the zobel resistors.
C1 and C2 are the 10uF bypass caps or BG 4.7uF N caps.
Could someone elaborate on how to check mute function?
Old 13th November 2004, 07:28 AM   #9
Oops, not the same problem...power to the amp board, but the chip's not hot.
Old 13th November 2004, 09:47 PM   #10
Yes, the problem is often very simple, once you find it.
Brian's instructions for the 3875 kit are pretty thorough, but almost nonexistant for the 4785. Does anyone have pics of their finished 4785 kits, or have advice to share about the differences in building the two?
Are non-conductive mounting bolts or washers necessary between the chip and heatsink?
onasis
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
LM4780 (3 channels not working) Dominick22 Chip Amps 5 30th May 2006 04:25 PM
WTB Krell KSA Mk2- working or non working Jozua Swap Meet 0 20th March 2006 11:14 AM
YES! i,m now the proud owner of a working LM4780 amp zei Chip Amps 11 30th October 2005 10:42 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
