| Chip Amps Amplifiers based on integrated circuits |
The MUR860 diodes have a maximum current output of 8A.
The maximum current output from a LM3886 is 11.5A. Are these diodes in a rectifier bridge still suitable if you are planning to get close to maximum power out of a LM3886? |
#2 | |
S. Roushon |
#3 |
Electrons are yellow and more is better!
I suspect that 8A diodes will work pretty good. You don't take out 11.5 A continuously (the LM3886 won't handle it) and secondly, the music isn't DC current. Notice also that the diodes will share the current because you have four of them.
I have an option for TO247/TO220 diodes in my QRP02 amp just for flexibility. I my case I have also fuses which breaks long for before 11.5A
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Do these diodes need to be placed on a heatsink?
#5 | |
Banned
Maximum ("non-repetitive surge current") is 100A. |
#6 | |
Banned
#7 | |
Banned
Realistically, it can be considered the "peak repetitive forward current", 16A. ON Semi datasheet, page 2. |
#8 | |
Does "non-repetitive" mean that the diode is no longer in a good state to take any current after it has taken that surge???
"Everything should be made as simple as possible, but not simpler." - Einstein |
#9 |
It means that you can't do it again and have a working diode. I think this diode will work just fine. Anybody who has blown a 8 A diode under normal conditions and with fuses?
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| Why the MUR860 diode? | meat | Chip Amps | 24 | 15th March 2006 07:35 PM |
| Pcb for MUR860 (or some else TO220 diode), rectifier bridge | peranders | Swap Meet | 14 | 17th September 2003 10:37 AM |
| Page generated in 0.09569 seconds (75.71% PHP - 24.29% MySQL) with 10 queries |
