| Chip Amps Amplifiers based on integrated circuits |
I have little experience with electronics so my question is probably gonna sound newbish.
I have a couple small chip amps out of PC speakers and they all have 16v 1000uf caps on the speaker outputs. If I take them out of the signal path the amp seems to draw max current even with little or no input signal. It draws so much current in fact that it melted the wall wart it was running off off. I'm sure it has something to do with the fact that the amp sees a load at all times instead of being frequency dependent with the caps in line. |
#2 | |
Output caps on power amps is usually due to using single power supplies. You shouldn't take them out or you can blow your speakers, as the caps are there to block DC which can fry your speakers. Carlos |
#3 |
Thanks Carlos, I figured that they were there to block DC, but I thought it was for the safety of the amp not the speakers.
The caps are 1000uf which starts to roll of the response around 40hz on a 4 ohm skeaker (i think). Can I put some better quality 25v 2000uf caps in their place, and would it be better if I used NP caps instead of regular ones? TIA, MEXXX |
#4 |
PC speakers with single supplies are usually cheap 2 speaker sets, with only a couple of watts output power (if you are lucky).
The speakers in them have almost no ability to reproduce sound below 40hz (I dont even think they can get that deep). |
| Output caps on DVD/CDP | hafp | Digital Source | 0 | 14th November 2008 06:49 PM |
| Value of output caps for Aikido - how low is too low? | cbutterworth | Tubes / Valves | 9 | 3rd September 2007 01:34 AM |
| Coupling caps in DAC output | Sunsun22 | Digital Source | 12 | 13th July 2005 06:04 AM |
| Zen output caps | apassgear | Pass Labs | 2 | 26th May 2005 06:38 PM |
| zen V4 output caps question | elviukai | Pass Labs | 3 | 4th January 2004 09:00 PM |
| Page generated in 0.07357 seconds (71.53% PHP - 28.47% MySQL) with 10 queries |
