Old 6th November 2004, 03:34 PM   #1
Cool gainclone from rat shack parts...
hello, i ve been interested in building a gainclone for quite some time now and just now got my "samples" from national semiconductor...i have 5 lm3875t chips and don't want to screw around with "exotic" components since this will be my first amp and i want to save some money on it...soooooo...i have been checking and it looks like radio shack should have everything that i need to build a gainclone but i don't know about transformers...i have never worked with them before and i need some info...information on the raido shack site is pretty scarce when it comes to their transformers...
will the transformers that radio shack has work for this?
if so which one should i get?
THANKS!
Old 6th November 2004, 10:11 PM   #2
mateo88 is offline mateo88  United States
I believe Radio Shack has a 24v center tapped transformer that puts out 5 amps. That would work nicely, but it might clip a little sooner than you would like. It can work, though. You won't be dissapointed with the sound quality, I can assure you. If you find the bass of the lm3875 a little soft or not punchy enough, try an lm3886. The only extra part you need for that is a mute resistor. Good luck, and happy building!
Old 7th November 2004, 12:27 AM   #3
garbage is offline garbage  Singapore
garbage's Avatar
Default SLA instead?
hi
not sure if 4x 12v Sealed Lead Acid battries are actually cheaper than transformers in US, but this is worth checking out if you want to build GC on the cheap. (one 12v SLA ranges from 10 - 12 odd USD here)
for charging circuit of the SLAs, you can use this : charger from vt52.com
cheers
garbage
Old 7th November 2004, 12:13 PM   #4
Default this one?
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CT LG%5F011%5F002%5F016%5F000&product%5Fid=273%2D1512
if so, cool!
Old 7th November 2004, 02:37 PM   #5
mrlots2do's Avatar
I did a search on Ratshack's site. Several transformers but not enough info posted. Visit a store, ask for models with 2 secondaries of 18-25v. Next problem is va rating, GC's need about 100va each.
Old 7th November 2004, 03:10 PM   #6
Sherman is offline Sherman  United States
Default Re: this one?
You really need at least 18V for a GC. The RS transformer is a 24VCT meaning it gives 2 x 12V, not enough if you use the CT. If you can find a larger transformer you do not have to have dual secondaries to have a dual bridge PS. I've built several GC PS with dual bridges using CT transformers.
If you want to use the RS transformer you can use 2 of these to create a dual bridge PS or just one to create a single bridge PS. As I said the problem isn't lack of dual secondaries, but lack of voltage.
--Sherman
Old 7th November 2004, 03:43 PM   #7
KCHANG is offline KCHANG  United States
Default The Rat Shack transformer is fine.
I've used the 25.2VAC CT 2A Radio Shack transformer in the power supply for powering my various Gainclones. It works just fine.
"You really need at least 18V for a GC. The RS transformer is a 24VCT meaning it gives 2 x 12V, not enough if you use the CT."
Depending on whether you are talking about AC or DC. The 2x12.6VAC will give a bit more than +-17VDC after the rectifier.
Ciao,
Kurt
Old 7th November 2004, 03:48 PM   #8
I thought u want to save money? What are you doing at RadioShack???
I'd say get your parts from a Fry's Electronics if you have one nearby. If not, you would be better off ordering them from a distributer for 10 cents a piece and paying 6 bucks to have it shipped.
Dont even think about powering an amp with a 2A transformer, especially only a 12-0-12 one. That would get like 10W peak output.
Old 7th November 2004, 04:00 PM   #9
Check out the listings at Apexjr.com in paticular he has a cute
little ~100 va 44v ct toroid for about $13 if you don`t push
the amp real hard this might work for a single channel. He also
has a lot of surplus caps.
Woody
Old 7th November 2004, 04:05 PM   #10
Even if you do push it, +/-30V or so is nothing to a 3875
Please Help sourcing Gainclone parts nelsondog Chip Amps 1 22nd February 2007 08:18 PM
My local Radio Shack is closing, what items to buy to build a cheap Gainclone? beady Chip Amps 17 15th July 2006 05:23 AM
First Gainclone - Help with Parts List schmalex Chip Amps 7 25th June 2005 06:41 PM
Parts for gainclone postman Chip Amps 6 23rd August 2003 08:34 PM
Page generated in 0.10381 seconds (80.12% PHP - 19.88% MySQL) with 10 queries
