| Chip Amps Amplifiers based on integrated circuits |
I am trying to get a PCB board made following the schematic for the 200W Bridge-Parallel specified in:
http://www.national.com/an/AN/AN-1192.pdf with 6 x LM3875 per channel instead of 4 as in the App Note. Before I send it I was hoping someone would point out any errors... The ExpressPCB file is attached. ExpressPCB can be downloaded for free at: http://www.expresspcb.com Thank you. |
#2 |
P.S. To open the LM3875B file with ExpressPCB rename it from LM3875B.PDF to LM3875B.PCB
#3 |
Why use LM3875 and not LM3886?
UrSv Those who say it can't be done should not stop those who are doing it. |
#4 |
I have a few LM3875's and no LM3886's...
#5 | |
#6 |
Thanks, I have just enough for one stereo amp... Any thoughts on the PCB?
#7 |
Nice job!!
I have some questions. Do you think that your speaker supply lines are thick enough? Consider how much current is going through them. And why no active servo? Makes for better power sharing amongst the chips. Food for thought. And a job well done. Mark
Mark |
#8 |
#9 |
Thanks for replying.
mwmkravchenko: good point on the thickness of the traces. thank you. I started with a servo version but it became too complex and I too lazy to finish it.... ![]() UrSv, nice work much cleaner than mine... Would you mind sending me your version? BTW, I didn't read the whole thread, did you end up making and building the PCB version? |
#10 |
I took a look ! its wonderful indeed
| Real-size pics from ExpressPCB | DragonMaster | Everything Else | 1 | 27th March 2006 04:09 PM |
| TO-220-11 library for expresspcb? | rs1026 | Chip Amps | 7 | 13th February 2006 08:34 PM |
| ALEPH 2 PCB (ExpressPCB Format) | ppereira | Pass Labs | 3 | 20th December 2004 01:13 PM |
| OPA549 footprint for ExpressPCB | sobazz | Chip Amps | 1 | 31st March 2004 04:07 PM |
| Page generated in 0.11324 seconds (74.93% PHP - 25.07% MySQL) with 11 queries |
