Old 6th November 2004, 08:25 PM   #1
D_GR8_1 is offline D_GR8_1  Australia
D_GR8_1's Avatar
Post OPA627 Active HPF
Hi guys,
hehe, this is my first post.
I am trying to design a HPF using the OPA627 op-amp.
I have simulated the design in Protel and ran simulation, however I am getting some weird results. (or so I think).
My HPF is supposed to be a 4kHz HPF.
The schematic & simulation plot is attached!
From my understanding of filters, the crossover point should be the -3dB point, right?
From the plots the -3db point is CROSSOVER/2 or 2kHz.
Also at the 4kHz point, the attenuation is -6dB.
Why is that?
Old 6th November 2004, 08:53 PM   #2
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
welcome to the forum !
the values for the resistors are wrong , check the pic i attached theres the formulas u need
Old 6th November 2004, 08:55 PM   #3
Swedish Chef's Avatar
I guess you are trying to build a 2nd order Butterworth HP. Then you should double the value of some resistors and capacitors - can never remember which ones but you can either do the math or just look it up on any site. The Texas Instruments (http://www.ti.com) site has a Filter Wizard that relieves you of the work.
For most filter characteristics the cutoff point is specified as the -3 dB point. Not so for Linkwitz-Riley (two cascaded Butterworth stages, hence the name Butterworth-squared) where it is at -6 dB.
/Magnus
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction
Old 7th November 2004, 08:06 AM   #4
D_GR8_1's Avatar
I used the formulas in the Texas instruments document "OPAMPS for everyone".
Are you saying those formulas are wrong?
Old 7th November 2004, 12:14 PM   #5
No, those formulas are right. Recheck your math.
/Magnus
Old 8th November 2004, 06:36 AM   #6
D_GR8_1's Avatar
Default 4th order Butterworth HPF
Which formulas would I need to use to design a 4th order Butterworth then?
Do I use the coefficients from the Filter Table ?
Old 8th November 2004, 10:40 AM   #7
It was a while since I read that document, but for a 4th order Butterworth - yes I think the coefficients are in the table IIRC.
But why would you like to use a 4th order Butterworth for audio?
Old 8th November 2004, 02:54 PM   #8
D_GR8_1's Avatar
Default 24db/octave
I like sharp cut-off curves. And a 24db/oct will provide that.
Or will it?
For example if I want to cut off my Subwoofer at 150Hz, I dont want to still play faint tunes at 500Hz.
What do you suggest?
Old 8th November 2004, 03:09 PM   #9
Ouroboros's Avatar
Download FILTERLAB (free) from the Microchip web site. It'll show you all you need.
Old 8th November 2004, 03:17 PM   #10
Yes, sharp cutoffs are good because they reduce the comb-filtering effect that results when more than one driver are playing the same signal. And they keep each driver in its best range (out of cone-breakup) and thus reduces distortion.
24 dB/oct is pretty much the gold standard for active filters.
But as good as the Butterworth response is for many engineering applications it is not ideally suited for audio active filters. If you add up the resultant acoustic output from an LP and HP Butterworth filter you will have a 3 dB bump in response at the crossover point. That is why you usually use a Linkwitz-Riley response which sums up flat and as a side bonus has a linear phaseshift between the LP and HP section. Thus they are also sometimes called "phaselinear" filters.
So there is no surprise that 99.9% of the (analog) active filters for audio on the market are LR...
The LR transfer function is very easy to obtain as it is just composed of cascaded Butterworth stages. So a 4th order (24 dB/oct) LR is made by cascading two 2nd order Butterworth's with exactly the same component values. A dual opamp like the NE5532, AD8620, OPA2604, TL072 or whatever will do the trick for one channel.
Once you have gone active you will probably never look back to passive filters. There is a reason why active filters are the standard in all pro sound applications today with passive crossovers rapidly becoming obsolete. And there is a reason why the "audiophile" industry sticks to passive crossovers and exotic components. Feel free to choose.
/Magnus
Active 3-ways with solen active loudspeaker module soundemon Multi-Way 14 19th March 2009 11:17 AM
Want to use OPA627 here arupg Digital Source 0 6th July 2007 09:40 PM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
im looking for 3 opa627! kasra Swap Meet 16 20th December 2003 09:30 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.12262 seconds (76.02% PHP - 23.98% MySQL) with 11 queries
