My first GC(lm3886) +fire works+ please help
Old 5th November 2004, 04:32 PM   #1
rs1026 is offline rs1026  India
Question My first GC(lm3886) +fire works+ please help
I built a lm3886 amp using Rod's design for lm3876.I used same component values.The amp worked perfectly well for 1-1.5 hours without any problem.But suddenly it went up in smoke with fire all around.I oberved that 100nf supply capacitor was totally burnt to ashes.Few neigbouring components turned black but luckily was not burnt.
Inspite of this I powered the amp and it played perfectly just like before.Inspite of bypass capacitor being quite near to 3886 the amp chip was not damaged.
I have used 100nf tantalum capacitor for bypassing and rest everything is electrolytic.Should I change the capcitor values or should I replacee even 100nf with electrolytic ones.
Please help.
Old 5th November 2004, 05:16 PM   #2
mcs is offline mcs  Denmark
Default Re: My first GC(lm3886) +fire works+ please help
Are you sure they are tantalum? The 100nF decoupling caps should be plastic film or ceramic caps.
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 5th November 2004, 06:38 PM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Are you sure it was 100 nF and at least 35-40 volts? It couldn't have been 100uF something low voltage? Did you get + and - right for the caps?
As Mikkel says, I recommend also 100 nF/63V polyester or ceramic.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 6th November 2004, 02:39 AM   #4
Default It is tantalum
I am sure it is tantalum.But there is no volatge rating on that.I guess as you guys mentiond polyester would be better.I have some 0.1uf ployester caps it says P26104K but then there is no voltage ratng on that too!!
Old 6th November 2004, 02:25 PM   #5
I have never seen 100nF polyester caps with a lower voltage rating than 63V, so I think they should be OK.
Best regards,
Mikkel C. Simonsen
Old 6th November 2004, 04:49 PM   #6
Default Thanks
Thanks guys,I think I will use polyester capacitor itself.i have cemaic disc type of same value but thought of using ployester ones this time.
My first GC(lm3886) +fire works+ please helpHide this!Advertise here!
Yey - LM3886 works like a charm Atilla Chip Amps 14 15th March 2013 01:23 PM
Which way to fire my sub? Gorbee Subwoofers 24 12th September 2006 12:59 AM
My LM3886 GainClone almost works! Big Pete Chip Amps 3 9th August 2005 07:11 PM
Ohhh Fire works (4780 Brian GT Kit) G4ME Chip Amps 24 7th April 2005 12:59 PM
Spring Loaded Terminal Post For Fire works Firing Rail ddpode Parts 2 4th July 2004 01:16 AM
