Old 5th November 2004, 02:50 PM   #1
JJJ is offline JJJ  Finland
Default Upcoming LM3886 SMD board
Greetings from Finland
I have been designing a little board to LM3886 audio amplifier IC. I have used SMD components to minimise board area and signal length. Board size is 80mm X 32mm, mainly because large capacitors.
This is inverting version but the non inverting is also coming at same board size of course. Some component reliefs have to be done before first proto PCBs but maybe some two weeks and first proto is ready to be tested.
Some comments please.
Old 5th November 2004, 03:29 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
Check the valure of the input cap once more, way too small. You will get a bass cut at 159 Hz! 10-47 uF is more appropiate.
C2, very thin ground connection and also in the wrong place. Try to get the power ground as compact as possible. Why don't you do like I have done? I have the power at the left and the signal at the right.
/Per-Anders (my first name) or P-A as my friends call me
Old 5th November 2004, 08:54 PM   #3
Yes the C3 value is definetly too small, didn't calculate that value, I just put it there, hmm.. maybe careless designing.
I don't know what you are meaning, is C2 in wrong place or ground???
That thin ground is not affecting ground potential or anyway it does not carry large currents . Main ground is deployd from those wire holes.
Old 5th November 2004, 08:54 PM   #4
I looked up that input capacitor and i have forgot input resistor from capacitor end to ground. With capacitor value 1uF and resistor value 10K, Low Fs would be about 16Hz.
Old 5th November 2004, 08:54 PM   #5
Raccoon is offline Raccoon  Finland
Hello
Im quite n00b on the board design, but aint C2 is getting its ground from the top layer, and that doesnt look too thin to me?
Othervice it looks damn simpple, at least if compared to your peranders. But aint yours a kind of all in one packed.
Old 5th November 2004, 09:15 PM   #6
peranders's Avatar
Sorry, I didn't see it clearly. Your grounding seems to be Ok.
The difference between your and mine design is that I have chosen to have low values for the feedback and this forces me to use a buffer and since I don't want any eletrolytic caps in the signal path I have chosen to have a DC-servo instead.
With a non-inverting buffert any signal source can be connected. If you have 10 komhs in your case you might have trouble to connect a potentiometer and if this potentiometer has too high resistance it will effect on gain and feedback of the LM3886. I'm not sure if you can bump into stability problems (gains less than 10). Otherwise a good layout. You have put the signal ground very close to speaker ground, that good and if you want to make it perfect, draw and insulated trace to the speaker ground pad. If you do that you avoid any voltage drops caused by currents to and from the C1.
You might manage without any output filters but if you have a difficult load it may not be good to omit the filters.
Old 6th November 2004, 09:02 AM   #7
I don't want those electrolytic capacitors in signal path so that input cap is kept kinda low, with 1uF value you have plenty manufacturers where to choose.
If you want to draw a simple small board something must be left out, and those output filters were mayby first ones.
Old 6th November 2004, 09:12 AM   #8
peranders's Avatar
....yeees...., but these may also be essential in some applications in oder to achieve good sound reproduction which has to do with a stable amp. These filters are for frequency compensation of the output stage (which may not be obvious) and also some protection for incoming RFI.
I don't know how you are going to make the boards but I think it's smarter to have those filter on board and start not to use them. It's very easy to add these filters if you experience problems.
Old 6th November 2004, 10:02 AM   #9
UrSv is offline UrSv  Sweden
UrSv's Avatar
If you mean that the amp side of the cap gets a resistor to ground then that will not make the Fs lower but higher since it will be in parallell with the previous determining impedance AFAIK.
UrSv
Those who say it can't be done should not stop those who are doing it.
Active filter plus LM3886 - one board MJL21193 Chip Amps 197 3rd November 2008 12:50 AM
look for LM3886 board mackin Chip Amps 7 29th November 2006 08:07 AM
lm3886 linkwitz board + ?'s on Eagle srfranci Chip Amps 5 16th February 2006 01:22 AM
Upgrading Lm3886 Board Caps filholder Chip Amps 10 21st April 2005 02:18 PM
Page generated in 0.12042 seconds (78.22% PHP - 21.78% MySQL) with 11 queries
