Old 4th November 2004, 01:01 PM   #1
Send a message via MSN to Scribble
Default Signal ground and pot
Ok need to brush up on my principles here.
Can some one explain to me why the signal ground must be connected to one leg of the potentiometer and then to the start ground?
Old 4th November 2004, 01:11 PM   #2
Send a message via Yahoo to psychosteve
because it sets the input impedance of the amp, by running the signal + to - across the full value of the pot.
hope that helps, steve.. ..
you all laugh because im different, i laugh because youre all the same.. ..
Old 4th November 2004, 03:31 PM   #3
audioPT is offline audioPT  Portugal
And helps to avoid ground loops
Old 5th November 2004, 02:05 AM   #4
Cheers for your great help fella's
Signal Ground ptah Solid State 4 29th February 2008 03:00 PM
1 signal ground or two? Rob11966 Tubes / Valves 11 14th July 2007 12:36 PM
~14 VDC between chassis ground and signal ground... StalfoS Chip Amps 3 5th May 2007 08:26 PM
signal ground and earth ground ttray321 Tubes / Valves 9 3rd May 2005 03:14 AM
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 3 28th February 2003 05:31 PM
Page generated in 0.25224 seconds (22.66% PHP - 77.34% MySQL) with 10 queries
