Old 4th November 2004, 12:53 PM   #1
Send a message via Yahoo to psychosteve
Default pots Vs sliders???
ok, on the input of lm3886, i can use a 50k pot, BUT..... ive got about 20 off 100k stereo sliders, is it ok to parallel the two sides together to get 50k??? and will it make more noise or less noise on the input than a single slider/pot.
ps, dont know if anyone saw, but Maplins in england are clearing out ceremet pots cheap. cant remember the values but it may be worth a look.
cheers guys, steve.. ..
you all laugh because im different, i laugh because youre all the same.. ..
Old 4th November 2004, 01:27 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Stick to the pot!
And if you want to get serious about sound quality, knock up a stepped attenuator!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 5th November 2004, 11:51 AM   #3
cheers bud, im not too woried about sound quality, i just didnt want to spend £5 on a decent pot, if the slider would do the same job. bearing in mind these are panasonic pro. disco faders and quite good quality, i just wondered if any one had tried paralleling sliders before and what the sound was like? cheers for the help Nuuk, steve.. ..
Old 5th November 2004, 12:00 PM   #4
Nuuk's Avatar
Wash your mouth out (and ears too?) with switch contact cleaner!
Old 5th November 2004, 12:41 PM   #5
Swedish Chef's Avatar
Every recording before the digital mixing console era has passed a few dozens of (high Q) sliders, although many of them were just there to control the voltage to a VCA. So go figure whether a single slider at the end of the audio chain will be detrimental for the sound.
As to the noise question, are you referring to the thermal noise of the slider or the artefacts introduced by mechanical movement of a poor quality slider?
/Magnus
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction
Old 5th November 2004, 12:47 PM   #6
The problem with slider pots is that except for serious ones, like Penny & Giles and Alps, most are rather bad. A pair of the good ones will cost you more than a good rotary type. Less than a switch + resistors though, if you go for 24 steps Elma or Shallcraft.
The adjustment is also critical, as only the long sliders will allow for some proper level adjustment.
They are also difficult to install, as you will need a very clean cut on the front plate, with nothing to hide it like a knob.
The only advantage is, if you use single ones, that you won't need a balance control when you set levels. You can move them both at the same time if you put them close to each other.
Carlos
Old 5th November 2004, 12:51 PM   #7
You stole my line
Lots of sliders, and also dozens of NE5332 and other 'bad' opamps
Old 5th November 2004, 01:35 PM   #8
ok to clarify a little,
the amp is lm3886 for powering 70 watt panasonic speakers directly crossed with motorola pietzo tweeters, to make 6 powered P.A. speakers.
im not woried about cut outs as itll all be mounted behind a cover in the back of each speaker. the sliders are only there for setting up, so i can adjust the volume of each speaker to compensate for room size and shape, while having a master volume at line level, prior to the amps, so wont be moved once its all set up.
cheers for the help guys, steve.. ..
Old 5th November 2004, 03:14 PM   #9
Then go for it. From what you describe sound will really be PA quality, which should be rather low-fi.
Carlos
Old 6th November 2004, 09:26 PM   #10
cheers guys, see you soon, steve.. ..
POTS! Get Your POTS! SmarmyDog Swap Meet 7 29th October 2007 01:19 AM
best hard setting plasticine to hand-mould knobs and sliders? VvvvvV Parts 2 28th January 2007 06:54 AM
need led light sliders for EQ project j_dunavin Vendor's Bazaar 0 7th January 2007 12:37 AM
Need 25mmx7mm continuous sliders tocs100 Parts 2 3rd December 2005 12:13 PM
Alps pots vs. TKD pots? TKD worth the extra$$? G Tubes / Valves 11 17th August 2004 04:33 AM
Page generated in 0.10122 seconds (79.92% PHP - 20.08% MySQL) with 10 queries
