| Chip Amps Amplifiers based on integrated circuits |
I have seen lot of discussion on this forum on GC using premium components but has anyone built a GC with all cheap/scrap components without bothering too much about using only metal film resistors or balck gate capacitors. was just curious
#2 |
I did.
#3 |
hi Igla,
Please comment on the results and whether you made a comparison to a commercial amp and/or a more expensive GC. Thanks! Brian |
#4 |
I did too - results
At least in its "on the cheap" incarnation the gainclone is not my cup of tea. Not terrible, but missing the detail of some more traditional designs. It's a decent starting point, perfectly suitable for less than super critical applications. |
#5 |
ive built mine with el-cheapo components and it sound good to me. Very clear and detailed but only thing i dont like is the lack of bass.
But then again im proberly not as perdantic as some other members of the board
#6 |
ive built tda 2030 chip amps with salvaged parts and that sounded fine to me. its ok if your sure of the values of components, a good multi meter, and preferably a capacitance meter. the trouble comes with resistors that look like 1watt, when they are only 0.2watt.
and what tollerance? 5%? 10%? 0.5%???? measure them, TWICE, then check again!!! then run them as a dummy load, a simple battery circuit, with a volt and current meter to check they can handle the stress your putting on them. see you later, steve.. ..
you all laugh because im different, i laugh because youre all the same.. .. |
#7 |
Well....I can try with my limited english.
I have used no-name metal film resistors which I had in my junk box (22k / 1k). For the power suply I've used Nippon Chemi-Con capacitors (1000uF)-cheap and the only brand available at that time in our local shop and one cube-like big 25A/600V cheap diode bridge. At the input cheap Piher pot and cheap film cap (Arcotronics; the gray one, I think MMK).All wirings made point-to-point of CAT 5 FTP cable. This was my first LM3875 NIGC and I must say that it sonicaly beat the s..t out of my AIWA 950.It also replaced my ZEN amp. The first big improvement was, when I removed the input cap. Then I replaced Piher pot with Alps blue-much more expensive but sonicaly quite an improvement. The next step was MUR860 double bridge-smoother mids and more defined bass.Then I replaced double bridge with just one. I can't say why I liked it more. The last improvement is different schematic (and same parts)made by Stefanobilliani- something like mix-mode current amp-look for the last scheme: http://www.diyaudio.com/forums/showt...threadid=41189). My parts have different values but the basics stays the same. I am still testing it.All I can say is, that this is totaly different soud comming out of my full range speakers. Igla |
#8 |
Thankyou for the comments.
Igla, your english is very good, much better than me trying ANY other language.
#9 |
Thanks Brianuk...you don't want to hear me speaking
german. I must say that my really first GC was inverted design by Thorsten schematics. After a while I just had to try non inverted design from LM3875 datasheet.I found it somehow better sounding. Then all the modifications followed. A few weaks ago I found an article Mr.Pass wrote about current amps and full range drivers. So I just had to convert my GC to current amp; well, some sort of mix mode amp.(check Rod Elliot page-variable impedance). Mr.Pass wrote that a full range driver hooked to a solid state amp sounds more like a kitchen radio. I can confirm that after the modification. Hard to describe the difference in sound....more like the difference between my old computer monitor with washed-out colours to my brand new one. The sound of NIGC on my full range loudspeakers is just washed-out comparing to the mix mode amp. |
#10 |
I've built several, all with very cheap components, and I do mean cheap. Just regular 10% carbon film resistors and some cheap 2200 uf capacitors. I've used both the lm3875 and lm3886, and I would strongly reccommend the lm3886 over the 3875. I just used the schematic from the data sheet, and there's much better bass response; it seems more detailed all around, as well. Really, I enjoy listening to my cheap gainclones with the lm3886 more than the one I have built using Brian's boards. You would be VERY surprised at what you can come up with for a few dollars.
| El Cheapo MCM FR drivers - has anyone used them? | Spasticteapot | Full Range | 19 | 7th March 2007 06:03 PM |
| El Cheapo HV source? | Spasticteapot | Planars & Exotics | 7 | 25th October 2006 11:38 PM |
| Cheapo Subwoofer | Relax | Subwoofers | 3 | 23rd January 2006 05:08 AM |
| Page generated in 0.11696 seconds (72.85% PHP - 27.15% MySQL) with 11 queries |
