Old 4th November 2004, 01:22 AM   #1
Default zobel question
I am planning (key word: planning) to build a 6-channel amp based on either the 3886 or the 3875.
Should I put a zobel network on all of the amps? none? or just the rear channels since the cables are much longer?
thanks!
Old 4th November 2004, 03:59 AM   #2
You should put a zobel network on all of the amps
Old 4th November 2004, 06:42 AM   #3
muhy3 is offline muhy3  Australia
Send a message via AIM to muhy3 Send a message via MSN to muhy3 Send a message via Yahoo to muhy3
I do not believe you should implement zobel's directly on the output stage of the amplfiier, because you may not know how the crossover/speaker that you will be using behaves. Once you have designed and built the amplifier you could try with and without a zobel network to see if sound is improved, generally you shouldn't hear any improvement if the amplifier is good as it will cope with some discrepancy in impedance but in the event that you do notice a difference the zobel network will most definately be good.
Also the zobel comes after the crossover from what i've read, but I may be wrong. http://www.trueaudio.com/st_zobel.htm
There used to be a time, when penguins filled the sky!
Old 4th November 2004, 06:49 AM   #4
Send a message via AIM to rx7speed
just figured I would ask a stupid quick question since the post is already here
what is a zobel network?
Old 4th November 2004, 01:39 PM   #5
Send a message via Yahoo to psychosteve
its a capasitor in series with a resistor, these are wired accross the output of an amplifier to help with certain loadings from speakers and cables, it can help if you have long cable runs.
its common to find them in PA systems where cables and speakers get moved and or leads are coiled up when in use.
whether you need one or not is down to your own hearing, it is worth trying it coz the parts are dirt cheap, and if it dont work, take it out.
hope this helps, steve.. ..
you all laugh because im different, i laugh because youre all the same.. ..
Old 4th November 2004, 01:45 PM   #6
Default one lump or two??
you used to be able to buy ready made cables for PA work with a zobel wired into the jack plug!!! so i wonder if using two zobel networks has any effect????? one each end?
HMMMMMMM, strange, this may need some experimenting... steve.. ..
Old 4th November 2004, 03:08 PM   #7
Mr Evil is offline Mr Evil  United Kingdom
There is no way to say for sure if they will be necessary. A Zobel network should have no effect on sound quality; they are there only to provide a low impedance termination for RF.
If all the amps are in one box, then my experience is that if one amp needs a Zobel then they should all have one, since stray RF from one amp can be picked up an amplified by another.
My advice would be to leave space for them on the PCB but not put them in initially. Use an oscilloscope to look for RF on the output and add them if there is any. Do this with the speakers and cables you are planning to use, in the location you are planning to use them. If you find you don't need Zobel networks, but at a later date start noticing slight fuzziness in the treble, check for RF again as it often manifests itself as slight distortion at audio frequencies.
https://mrevil.asvachin.eu/
Old 4th November 2004, 03:27 PM   #8
I implemented my zobel externally at the output post when there is a need. Usually I dont have it 'built-in'.
Old 4th November 2004, 05:42 PM   #9
Did it Himself
richie00boy's Avatar
There is a lot of misunderstandings circulating regarding zobels. Please see my post for the all the answers
Zobels aren't there for protection against RF, but this can be a byproduct.
Old 4th November 2004, 06:52 PM   #10
Compensating for an inductive load and terminating RF are manifestations of the same thing, Inductive loads aren't a problem if there is never any RF on the output, and conversely any RF that appears on the output won't be a problem if the load is not inductive (although there may be cases where you need a Zobel to prevent instability with no load connected which has nothing to do with inductance of the load, due to high output impedance of an amp at RF).
zobel question sakis Solid State 11 26th September 2008 08:51 AM
zobel question? fazman Multi-Way 2 18th December 2005 04:11 AM
Zobel Question Soulwax Multi-Way 2 2nd May 2005 05:21 PM
Zobel Question poeee Chip Amps 2 5th January 2005 05:29 PM
Zobel question soundNERD Chip Amps 12 29th March 2004 11:57 AM
Page generated in 0.11133 seconds (75.33% PHP - 24.67% MySQL) with 10 queries
