Got some parts with my NIGC kit that I don't know what to do with
Old 3rd November 2004, 05:02 PM   #1
TheDriver41 is offline TheDriver41  United States
Default Got some parts with my NIGC kit that I don't know what to do with
I got what looks like a resistor saying "2.7ŲJ 2W" and a small relay looking thing saying "100n CR 63v BC 0423416."
I didn't find them on the parts included on the guide. Any ideas?
Thanks,
Matt
Old 3rd November 2004, 05:44 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Sounds like a Zobel network to me. If it is, then you connect them in series between the two speaker terminals.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 3rd November 2004, 10:42 PM   #3
Evan Shultz is offline Evan Shultz  United States
You didn't say if it was the LM3875 or LM4780 GC kit. However, Nuuk is right: they are the Zobel network.
2.7ŲJ 2W = 2.7ohm 2W resistor
100n CR 63v BC 0423416 = .1uF cap
There is a spot on the 3875 boards for the Zobel, not sure about the 4780. As an alternative, you can connect the parts in series across the speaker terminals for the same result. Peter and Brian have both suggested to only use the Zoebel if required, and there are many happy GC owners who do not use it. Unless your speakers cables are exceedingly long, or exceptional capacitive, I suggest you leave the Zobel off or at least listen both ways.
Old 4th November 2004, 12:45 AM   #4
metha is offline metha  Thailand
Question Order of R/C for zebol- RC or CR ??
About the order of R C for zebol. I am curious. Typically I connect the zebol R (1 ohm) to the speaker out (signal) and the Cap ( 0.22 or 0.1 UF) connect to the speaker ground.
I found some GC board connect the R C reversely (i.e. the zebol R connect to the speaker ground instead). Any difference between both approarch?
Old 4th November 2004, 01:20 AM   #5
soundNERD is offline soundNERD  United States
Nuuk, would it be better to actually connect it on the speaker? or on the amp PCB? both?
sorry if it's a stupid question
Old 4th November 2004, 02:31 AM   #6
Sheldon is offline Sheldon  United States
Default Re: Order of R/C for zebol- RC or CR ??
Nope. The output is AC, so no polarity concerns.
Sheldon
Old 4th November 2004, 02:33 AM   #7
The normal recommendation is to place it on the board, or near it. That short circuits any high frequency resonances closest to where they would be generated.
Sheldon
Old 4th November 2004, 07:24 AM   #8
Nuuk's Avatar
Thanks to you guys for taking over while we UK chaps took a nap!
Yes, as Sheldon says, the Zobel needs to go close to the amp, ie on the terminals or even on the PCB if there is room.
Old 4th November 2004, 08:12 AM   #9
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Sheldon
Actually, it's nothing to do with shunting resonances. You place it close to the board because the further away you place it the higher the inductance of the connection, which limits the zobels usefulness (as it is trying to compensate for the phase angle caused by inductive loads).
Not quite. If your speakers or leads present a highly capacitive load, you should add an output series inductor. The zobel is for inductive loads.
Old 4th November 2004, 10:40 AM   #10
rnoble is offline rnoble  Australia
I noticed this thread and headed down the shop to to add a zobel to my Gainclone to see what the fuss was about. I feel that there's been an improvement in sound, particularly there was a little level difference between LR that seems to have gone - but most noticeably the top end seems less forced and less forward, perhaps less bright? It is hard to put a Zobel on and off with a switch so I can't discount a possible placebo effect, however I do feel it has compensated to the audio quality in some small improvement.
Worth a try.
Cheers
Rod
All that is not given is lost.
Got some parts with my NIGC kit that I don't know what to do withHide this!Advertise here!
NIGC 3875 Distortion? tkelley Chip Amps 12 8th March 2005 12:39 PM
NIGC Buffer Assesears Chip Amps 21 2nd September 2004 07:36 AM
NIGC input resistor tonitze Chip Amps 1 14th May 2004 05:50 PM
Wiring preamp and NIGC miguel2 Chip Amps 5 30th December 2003 04:53 PM
Reducing DC offset on a NIGC? Optical Chip Amps 21 21st December 2003 06:43 PM
