Old 3rd November 2004, 01:24 PM   #1
Franz G is offline Franz G  Switzerland
Franz G's Avatar
Default What is the simplest way, to convert this GC to a subamp?
I am looking for the simplest idea, to convert this NIGC to a subamp:
- what is the easiest method to filter (lpf 100Hz), eg. use a buffer or not?
- what is the easiest method to mix both stereochannels?
Thanks for all ideas!
Franz
Old 3rd November 2004, 01:37 PM   #2
miguel2 is offline miguel2  Portugal
In the Pass Labs diy site you find the articlle of el pipe-o with a filter to be connected to output of the main speakers amp.
Miguel
Old 3rd November 2004, 01:40 PM   #3
jackinnj's Avatar
try this:
Old 3rd November 2004, 02:39 PM   #4
Franz G's Avatar
Do I interpret this correctly?
This circuit is showing a crossover, mixing two channels and using two opamps (like OPA627).
So, I could bridge or paralleling the two output chips in this case.
Franz
Old 3rd November 2004, 04:38 PM   #5
Banned
That's right.
You sum the two channerls, then filter after that.
That way, you use half the parts because you don't need to apply filtering per channel.
On an already-made amp it's more practical to parallel.
EDIT:
Oh.
The summing op-amp has to be inverted.
Old 3rd November 2004, 05:32 PM   #6
Franz G's Avatar
Oh.
Could you explain this? I dont understand.
Franz
Old 3rd November 2004, 05:41 PM   #7
jackinnj's Avatar
maybe we can dispense with the buffer, etc. in their entirety -- although I would hold my breath -- i haven't wired this up:
Old 3rd November 2004, 06:07 PM   #8
Franz G's Avatar
3.83M for the feedback resistor?
No, remember the t-net! Too high resitance for a good feedback, nearby 4M!
I think, it is better to use dedicated opamps for filtering, when I look at this circuit!
Many thanks, jackinnj! I will try the first circuit, you showed in this thread.
Franz
Old 3rd November 2004, 06:45 PM   #9
Banned
Franz
Sorry, my confusion.
It can be inverting or non-inverting.
But with some requirements, if you don't want to have high DC-Offset.
Here is my sketch from when I made my sub.
I used an OPA2132 as input buffer and then an OPA4228.
Power amp is 2 // OPA549s.
Old 3rd November 2004, 06:57 PM   #10
Tube_Dude's Avatar
Hi Carlos
You were right!! A inverting stage is better for summing two channels, because the summing point is a "virtual ground" and don't permit signal leakage from one channel to the other...
À nossa!!
Jorge
B&W ASW-4000 Subamp ManUtd Solid State 9 3rd May 2012 09:17 AM
horn subamp design space2000 Subwoofers 2 28th May 2008 02:16 AM
jast finished diy n-ch car subamp tmyr Car Audio 23 23rd August 2006 07:39 AM
FS: PE subamp, drivers - Australia rabbitz Swap Meet 2 6th April 2004 01:05 PM
Car subamp 50W on 12v palesha Solid State 11 14th July 2002 12:35 AM
Page generated in 0.11665 seconds (75.38% PHP - 24.62% MySQL) with 11 queries
